how to take out stock hu
Old May 1, 2009 | 08:31 AM
richardsayzz's Avatar
Default how to take out stock hu
How would i go about taking off the headunit to get to the back ?
going to install a sub to my stock stereo...
Old May 1, 2009 | 04:57 PM
AndreyCo's Avatar
Stock stereo doesn't have RCA outputs. You would have to buy a line converter.
But anyway...just pull on the entire part that surrounds the stereo with the vents. It helps if you put your thumbs inside of the vents and pull. There are 4 clips holding that in. After you take that off, there is another small piece you should take off thats is right under, again just pull it right out. There should be two clips holding that in. After you take off those two parts, you should see 4 12mm bolts holding the stereo in. If you don't know what to do at this point, put it everything back together and take your car to a professional before you break anything :-)
Old May 1, 2009 | 05:13 PM
Big_Bird's Avatar
Searching is a good way to start.
Need to learn how to search properly, click this:
https://www.scionlife.com/forums/viewtopic.php?t=27618/
Found these in 2 minutes.
https://www.scionlife.com/forums/vie...ghlight=taking
GoodVibes
Apr 8, 2015 05:30 PM
SloTC1
Apr 2, 2015 07:11 PM
SuBSiN
Mar 13, 2015 04:02 AM
mischman
Jan 14, 2015 06:07 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
