xB in the snow?
Hey guys,
Looking at buying an xB and was wondering how they were in the snow.
Normally, I put my vehicles away for the winter, but, seeing as Scion's in Canada are few and far between, I have to jump on this deal right now. Therefore, ill be driving it for the rest of the winter.
Opinions/experiences?
Thanks.
Kris
Thanks.
Kris
The xB handles amazingly in the snow. With VSC, traction control, and ABS all standard, plus FWD, it's fery good for snow driving. The VSC is amazing and will keep you going straight in just about anything. The only downside is the low ground clearance (I think it's 6.1") I can't tell you how many stuck vehicles I rolled past in our recent arctic storm.
I would not worry about replacing wheels or tires for snow driving. The stock tires do very well and are actually more of a snow tire. I have them without any problems. I am actually waiting for spring to get different wheels and tires since they do so well.
There are a whole lot of snow topics in this forum, try searching.
If you get one, you will not be disappointed, unless you plan on driving in deep snow. If there is regular plowing, you have nothing at all to worry about.
Check out this post I did a while back...
https://www.scionlife.com/forums/vie...487&highlight=
yeah i have the stock steelies on right now...it sucks..i miss my 18"s but those sucked in the first and only snow they saw...oh well its gonna get warmer in chicago soon enough
The xB has 6.1" of ground clearance which is about 1" MORE than most cars on the road today.
That is measured from it's *lowest point* somewhere on the lower suspension arm.
The front ground effects are about 8" from the ground which is as much ground clearance as many SUV's.
The xB just "looks" low to the ground because it is square.
I am from New Hampshire and my box did pretty well in the snow. The traction control really helps. But by no means can you go on the road and expect to ralley the car around like an STi or EVO but it hold its own with a good driver that know how todrive in those conditions. Snow tires would be a good add on.
does the traction control turn on by itself? I just had some bad snow, and it really didnt seem to handle that well in the snow - it was my first time in snow, so i dont know what to expect. It didnt skid, but if i press the gas or brakes down quickly it seemed to have no traction control
My xB has now been in a lot of snow, and well I'd have to say it's really no different from any other traction controlled, ABS equipped, FWD car. Which now adays, is pretty much all cars other than A/4WD jobbies.
We just had a first decent snow here in central virginia... I left work around 2:15 a.m. and there was ice everywhere and the roads weren't too good either. My xB did great though I took it slow to be careful.
On a side note, that beeping the VSC makes when the car starts to slide is freaky.
Well I am in ohio and we just got a light dusting last night well thats what the weather man called it - I call it 6 to 7 inches at my place. Anyway on to the topic. The box Rocks - plain and simple. It was the first time I had a chance to really put it through its paces.
First and foremost the Traction Control.
Off - the car sucks and spins and spins and spins. Most likely due to the awsome power under the hood, and the low weight of the car.
On - just stomp the gas and away you go. I would however disagree with a previous poster. I believe this is a more sophisticated version of traction control, Primarily due to the fact that we also have VSC. A very simple TRAC will simply pass power to the non - spinning tire, this is generaly referred to as a limit slip. This generaly however leads to both tires spinning and you going no where. A more common application of TRAC would be one that applies slight brakeing to both wheels and or reduce power to increase the likelyhood of getting grip.
Now a more sophisitcated system like what I believe to be in our cars would would monitor the driving wheels and as one begins to rotate significantly out of sync with the other as well as in realation to the forward movement of the car. A small amount of breaking would be applied to the spinning wheel to bring it back in line with the other. That is why you do in fact get some wheel spin with trac on because its a gradual application of breaking since you are generally not in trouble when accelerateing. So kudos to Toyota for equiping this little guy with top of the line traction control
now the VSC. It is one smart little cookie.
You can in fact induce your car to spin if you TRY to do so. This system apprears to watch a lot of the actions taking place in the mechanicals of the car. For instace, sawing your wheel back and forth on a snow covered road getting all slippy and slidy will not, I repeat WILL NOT engage the VSC. Some how the brain knew I was trying to play based on my quick steering input throtle and aI am sure a viariety of other items. However after I was done having fun in the parking lot as I was pulling out I made a left hand turn onto an access road, very gently mind you because now I was entering public access. The rear end bust have engages some ice and it snapped what seemed like a couple inched out of whack. BEEP BEEP BEEP VSC caught it and corrected before I realised it was on.
Boys and girls let me tell you the BOX has a very sohpisticated VSC AND the TRAC uses the VSC mechanics and brains to provide us with a very capable white weather mobile.
Now my only problem is finding mine when it snows that much. Polar White? Yep thats about right.
^^^^good post^^^^
I was making the point that it is not the TRAC alone that keeps the box going where you want it to, it's the combination of TRAC and VSC. Some people giveTRAC more credit than is due. It just helps you get going...not to stop you from spinning.
And you were right, it is the more sophistocated form of the TRAC that we have, it brakes the slipping wheels.
Agreed. The computer system in the xB is very sophisticated and smart.
By tying the anti-lock braking system to the computer and using a series of Yaw sensors, wheel speed sensors, and throttle control, the computer can figure out where you want to go and compare it to where the vehicle is actually going, then correct it within mere seconds by using the following...
Traction Control: gets you started by keeping the wheels from slipping.
Vehicle Skid Control: saves you if you start to skid by braking 1 to 3 wheels to correct your path
Anti-Lock Brakes with Brake Force Distribution: makes your stops short and straight with little to no sideways skidding
Now remember kids, the computer cannot overcome the lays of physics.
If you push it too hard, there is only so much the little car can do
to save itself from the loose NUT behind the wheel.
