MSCOFF
01-24-2004, 02:49 PM
I bought an Echo for my daughter about a year ago. Weak AC, so I insulated the line in the engine compartment and got a noteciable increase in preformance, My Mazda 323 is ready to go and I'm concidering a Scion xA. I've seen posts at Edmonds about poor AC in the Scion. Any experiences or cures? TIA Mark S.
Munch
01-24-2004, 03:08 PM
It's the same as the Echo, so I guess what you did in the Echo would work for the Scion, but don't quote me on that :) .
its_ikon
01-24-2004, 06:29 PM
i haven't had any problems with the ac, but people expect different things from a car.
DibujoB
01-24-2004, 06:43 PM
I notice on a lot of them (I work at a dealership and drive a lot of them, and I own one also) that the AC is kind of weak. What I'm finding is that after the car breaks in a little bit, the AC improves dramatically.
On my own xB, the AC didn't start working well until I had about 100 miles or so on it, but now it works awesome.
jdtjunior
01-24-2004, 09:18 PM
Just a quick question..............Why does the car need to "break in" for the AC to start working? Is that normal? Sounds kinda odd to me
a330300
01-26-2004, 07:56 AM
I used the pipe insulation and alunminum tape method on my xA, defininitely improved the A/C.
tvdang7
03-08-2009, 09:14 PM
i want to insulate my pipe to see if it makes it any better. my AC is REALLY weak when in idle it actually blows heat but once the car starts moving back to chilly air. Where should i insulate is my question? Any pictures would help.
kentuc
03-08-2009, 09:22 PM
Make sure your electric fan is coming on with the A/C.
tvdang7
03-08-2009, 09:33 PM
so i just park the car and turn on the ac and check to see if the fan near the radiator is moving?
i insulated mine and had my windows tinted
the window tint helped the most!
kentuc
03-09-2009, 02:21 AM
Engine running with the A/C on.
lazermule
08-02-2010, 11:35 PM
My 2005 XA Auto air conditioning compressor will only engage when the engine rpm is above 3500. It is fully charged and has no leaks. The car has 40K miles on it. At idle, it has NO air conditioning.....but, occasionally if the air is running strong and the rpms come to an idle the a/c will sustain for a minute or 2 but not very often...
What would cause this? I have evac'd the system, recharged it and have all the service gauges and all reads well....just cant figure it out. I have to run down the freeway with overdrive off to have air conditioning....
Initially, I thought it may be a weak compressor,but at 40K miles? And why would it sometimes work at idle??? Flaky pressure switch maybe???
Love the car, but HATE this problem.....:?
Any help would be appreciated...
LM
