View Full Version : Quesion About These Wheels
Alexisonfire
05-03-2009, 06:27 PM
so im most lileky going to be purchasing these wheels for my 08 BRM tc but in the picture it shows only a 4 bolt patter but the info says 5-100 now i dont want to buy them and find out they sent me ones with a 4 bolt pattern what do you guys think i should do?
these are the wheels http://www.discounttiredirect.com/direct/findWheelDetail.do?bp=5-100&yr=2008&pc=75346&counter=2&wd=17&rw=7.5&vid=012503
Jlowe
05-03-2009, 06:40 PM
That's just the product image. They will send you 5X100.
Alexisonfire
05-03-2009, 06:44 PM
okay thank you, those will fit right they are 17X7.5 5-100 45G im on my 17 inch stock tires
XIEmperorIX
05-04-2009, 02:34 AM
by 45g i'm assuming you mean the offset is 45mm? if thats the case then yeah these will fit fine..if i'm not mistaken they are only .5in wider than the stock wheels.
10gxiong
05-04-2009, 07:41 PM
those would look nice. if only they were 17x8 +35... they'd be perfect.
Alexisonfire
05-04-2009, 10:33 PM
they will fit my stock tires correct?
BZinn1
05-04-2009, 11:59 PM
yes they will fit perfectly with your tires,will sit almost exactly the same position in the wheel well as the stock rims.......it will work good.
