quick question about turbo set up.
Old May 8, 2009 | 04:37 AM
dynamicTC's Avatar
Default quick question about turbo set up.
alright so i just got my car inspected so i can finally get one of my kits on .
ithe one im going to use for now is a zpi stage 0 . was wondering if i would be fine running it at 8psi ? untuned ? and with stock injectors . i have 700cc injectors for my other kit but i dont know if i should run injectors that big on a stage 0 set up ?
any help would be much appreciated
Old May 8, 2009 | 06:08 AM
GhostFaceKilla's Avatar
I wouldn't trust driving around un-tuned.
Old May 8, 2009 | 07:03 AM
blacktrdtc's Avatar
HaYu Racing
Default Re: quick question about turbo set up.
your car will end in fail if you do this i think. take your time and do it the right way. definitely with a tune.
Old May 8, 2009 | 07:11 AM
Mrsanchez925's Avatar
if you are going to boost 8psi , PLEASE get it tuned and bigger injectors....
Trust me it will save you alot of money and head aches....
Old May 8, 2009 | 10:45 AM
Scoobasteve4132's Avatar
yea I am pretty sure 8psi, no injectors, no tune = boom!
Old May 8, 2009 | 12:30 PM
BlackKnight's Avatar
Music City Scions
FAIL
700's isn't that big on our cars for 8psi, you will probably be running around the same duty cycle as oem injectors. Meaning the injectors aren't working hard at all and will last longer also by running 700's you have room to turn boost up some.
Bottom line get tuned and upgrade your fuel system to include pump it isn't that much for to gain a lot of reassurance its done right.
Old May 8, 2009 | 12:35 PM
CarbonXe's Avatar
Do things right or don't do anything at all.
Old May 8, 2009 | 01:58 PM
rhythmnsmoke's Avatar
Music City Scions
NO to 700cc, and NO to 8psi of boost on a Stage 0 or like setup.
Old May 8, 2009 | 02:08 PM
Music City Scions
I need to pay more attention to the turbo you mentioned. Only 550's - no 700's
Old May 9, 2009 | 06:24 AM
dynamicTC's Avatar
ok .
just asking a question . thats all i needed to know .
and i do have a better setup . i just wanted some boost back for now.
and i was already boosted. but the piggy back pooped the bead so i cant run my original kit . so i was just going to run my stage 0 i had here .
but thanks for everything .
Old May 9, 2009 | 07:25 AM
scikotictc232's Avatar
you dont make sence
Old May 9, 2009 | 09:56 AM
Music City Scions
somethings to remember when it comes to engine and injector size:
1. is your fuel pump sufficient for what you need
2. is your fuel lines sufficient for what you need
3. do you need a adjustable fuel pressure regulator
4. There is a calculation for RPM of your engine to determine the max possible injection pulse with you can have at a certain RPM. I don't remember the exact calculation but it takes into factor engine cylinders, cycles (4 stroke), and rpm. Even though you think you may have big enough injectors you can use this determination to see if you really do at higher rpm ranges. For example you determine max pulse width at 6500rpm can only be 4ms and you are running lean and need to richen it up but you are running 4ms then you will need to see if it is possible to up your fuel pressure if not then you will need bigger injectors.
my06tc
Jun 25, 2015 12:18 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
spawnconnery
Dec 18, 2014 08:38 PM
BLKTOYBOX
10
Mar 2, 2004 08:36 PM
