Guage Cluster Info
Old May 8, 2009 | 08:38 PM
rangerryda's Avatar
Default Guage Cluster Info
Hey everyone, new to SL. I took the aforementioned advice and checked the search function before asking my questions. #1. Does a used gauge cluster from a 2005-2006 Scion TC fit/function the same as a 2007? #2. When/If the cluster is swapped, does it retain the mileage from the previous vehicle or is that information stored elsewhere? I'm hoping that the harnesses/connectors from 2005 will fit my 2007 and the mileage will show true to the mileage on MY car...not the previous one. Thanks in advance!
Old May 8, 2009 | 08:43 PM
SquallLHeart's Avatar
mileage is stored on the cluster.
Old May 8, 2009 | 10:27 PM
rangerryda's Avatar
Man that sucks. So easy to commit mileage fraud . Either way, does it have the same connection harness? Reason I'm asking is because I want an L.E.D. swap done and faceplate change and don't want to lose/modify my factory gauges at any point in time. The center stack just has a removable assembly on the back that needs modification for the L.E.D. swap right?
Old May 9, 2009 | 04:40 PM
Garage1217's Avatar
Correct on the center HVAC. Also not so easy to commit fraud as the milage is also stored on the ECU, they are a matched pair
Old May 9, 2009 | 09:08 PM
shupes31's Avatar
since the mileage is also stored in the ECU... is it possible to get my mileage (actual) onto a new gauge cluster?
Old May 19, 2009 | 05:07 AM
LEDmod's Avatar
I can transfer your old miles from the older gauge cluster on to your new gauge cluster...
Old May 19, 2009 | 03:34 PM
shupes31's Avatar
is there any way that can be a DIY? my car is my daily driver so I really can't drive send my gauge cluster anywhere.
Old May 19, 2009 | 10:19 PM
yellowxhoodie's Avatar
im pretty sure the dealer can do that as well.
Old May 20, 2009 | 12:58 AM
LEDmod's Avatar
I can send you a loaner while I work on it (1-day turn around)
Sorry, there is no DIY for it...
Old May 20, 2009 | 12:59 AM
LEDmod's Avatar
If you do them through warranty...
Most likely they won't do it.. or they could charge you arm and leg...
olyellr
Sep 28, 2015 10:32 PM
sccarally
Regional - Lonestar
Sep 27, 2015 09:24 PM
wayneside
Regional - Southeast
Sep 23, 2015 10:42 AM
wayneside
Regional - Pacific Northwest
Sep 23, 2015 10:29 AM
kslim619
Sep 18, 2015 06:54 PM
