Extended Studs
Old May 10, 2009 | 10:13 PM
dodaddy's Avatar
Default Extended Studs
I wasnt sure if I should post this under wheel and tire, but I figured this would be a better place to post, done a lot of searching on SL but no luck.
Does anyone know where I can find extended wheel studs longer than 50mm for the tc? The only ones I could find were ichiba. I was looking for 60mm +
Old May 10, 2009 | 10:19 PM
BZinn1's Avatar
How long are the Skunk 2 bolts????
Old May 10, 2009 | 10:20 PM
dodaddy's Avatar
i think they are 75mm+ but i dont know if it'll fit! my friend wants to sell me his set but i dont know if it fits or not, and it will be wayyy to much work to test it lol
Old May 10, 2009 | 10:30 PM
BZinn1's Avatar
I wondered how long they are........75mm is really long.
Old May 10, 2009 | 10:42 PM
dodaddy's Avatar
How long do u think the OEM wheel studs are?!
im thinking about ordering these ones
50mm ones
http://www.monstermarketplace.com/Au...g3810a857.html
Old May 10, 2009 | 10:43 PM
imsonofagun's Avatar
I know Ptuning has extended wheel studs. I'm not sure how long they are though.
http://www.ptuning.com/html/Item-Des...l&ModelDesc=tC
Old May 10, 2009 | 10:52 PM
dodaddy's Avatar
^^ omg thank you!! I did not know they made those at all, imgonna give htem a call tomrorow and check the length
Old May 10, 2009 | 11:16 PM
BlizZard's Avatar
x2
it took me a couple of hours but I got it done haha
It was the hardest thing I installed on my car (the front sway bar was a close runner up lol)...basiclly, I think if you could install new wheel studs you could install anything on the car lol
Old May 10, 2009 | 11:24 PM
dodaddy's Avatar
^^ what wheel studs did you pick up blizzard?
Old May 10, 2009 | 11:34 PM
davedavetC's Avatar
wheel studs are soooo easy, especially the fronts, i got both sides done in about 30 min (including taking off and putting back on the brakes).
are you using air tools?
and how did you install the studs?
Old May 10, 2009 | 11:39 PM
dodaddy's Avatar
which ones did u pick up davedave?
After some extensive researching I noticed that the skunk2 model for the honda 5 lug and scion 5 lug are the same numbers! do u guys think that means they will work!?
http://www.racingworks.com/skunk2_ex...heel_studs.htm
Old May 10, 2009 | 11:44 PM
davedavetC's Avatar
i had the H&R studs that came with their spacers.
what about the toyota 5 lug at the bottom?
Old May 10, 2009 | 11:47 PM
dodaddy's Avatar
the toyota one matches up with the scion too! im gonna contact htem and see if it fits, but if someone else on here knows for sure I will attempt to put them on asap
Old May 11, 2009 | 12:00 AM
BlizZard's Avatar
I have the Ichiba set.
so easy? this guy! lmao
I didn't use air tools which made everything more harder and tedious.
I hammered out the old studs and to install the new ones I bought a cheap open ended lug nut and tightened them in until the stud "sat" in the hub. It was a pain in the a$$, and I don't think I'll ever do it again lol
I did however use air tools to install the front hotchkis sway bar and everything went smoothly ...wish I did the same for the studs -_-
Old May 11, 2009 | 12:57 AM
tc-guy's Avatar
careful on those lugs. the thread pitch is the same but the knurl(the bottom part of the lug) is different for hondas and scions. hondas knurl is slightly smaller.
both honda and scion have 12x1.5mm lugs but the knurl is slightly smaller for hondas.
if it is slightly smaller it might not set in nice and tight. the knurl on scions and toyotas is supposed to be 14.3mm. honda is 12.3mm.
Old May 11, 2009 | 01:25 AM
davedavetC's Avatar
lol thats why.
when installing the studs, just get a bunch of washers, and a regular nut that fits on the studs (12x1.5) and tighten it that way with an impact gun. it gets teh job done quickly and easily
Old May 11, 2009 | 02:02 AM
BlizZard's Avatar
...that would work too
haha frickin Dave! Where were you 5 months ago when I needed this info?? lmao
Old May 11, 2009 | 03:29 AM
HKSpeed's Avatar
those PTuning studs are repackaged ARP studs ( http://www.arp-bolts.com/Catalog/Cat...atalog066.html ). really nice, but really expensive.
you can order individual studs from H&R, which are the same ones used on their spacer kits. theyre alot cheaper. http://www.hrsprings.com/applications/studs
you can only order them through authorized H&R dealers, not directly from H&R
Old May 11, 2009 | 03:46 AM
davedavetC's Avatar
lol i was here, you should know that you can always message me lol
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rvascion
Nov 12, 2020 03:23 AM
TotalChaos
Jan 21, 2016 11:27 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Mike_xb2
Scion xB 2nd-Gen Wheel & Tire
Sep 10, 2015 01:18 AM
