Camry Block with Scion Engine Bay
Old May 11, 2009 | 05:25 AM
ToyoCel's Avatar
Default Camry Block with Scion Engine Bay
Ok I used a camry engine with my new motor which I thought wouldnt be a big deal. Turns out the Timing Chain cover has a different mount set up for the top left (passenger side) mount! All other mounts fit perfect. My car is tuned and ready to go but im afraid my motor with fall down, destroying my axles, power steering or even more. I need advice. Has anyone else done this before? Would I need to fabricate something? I need advice not dumb remarks please. Thanks
Old May 11, 2009 | 05:26 AM
gingles's Avatar
hmmm.....i thought 2az's were all the same
Old May 11, 2009 | 06:08 AM
jsg93085's Avatar
definitely not the case... in addition to CR changes between models and model years, the 07+ has oil squirters in the crank area that are missing in the 05-06 (which some believe solves the tendency of the 2AZ to burn oil)
i would say compare the mounts and see if a stock tC mount can be modified or check into getting one fabricated...
Old May 12, 2009 | 12:03 AM
TRDIZZLE's Avatar
interesting stuff. what year was that camry motor?
Old May 12, 2009 | 04:10 AM
Windu's Avatar
Can you use your tc timing cover and ditch the camry cover?
Old May 12, 2009 | 06:23 AM
ToyoCel's Avatar
Ok well after extensive research this is what I've found. You CAN ditch the timing chain cover! The bolt pattern for both covers are identical. The only difference is the outside of the cover where the motor mount attaches itself to the cover. I also found out that the motor I have is equiped with oil squirters that reduce the changes of burning oil. The cover is expensive so i think im going to have a motor mount braket fabricated. Hope this helps anyone whos ran into the same problem or considering using a camry motor.
Old May 12, 2009 | 06:55 AM
BlackKnight's Avatar
Music City Scions
Motor building company found out in the beginning that even though its a 2AZ-FE from the Camry and Scion tC share the same engine they found differences in the bearing and a few minor other things. This was in middle of 04 when the 05 tC's were rolling out. They purchased parts from the dealer for a Camry with the same engine but found different parts.
Old May 12, 2009 | 10:19 PM
Shaka_Z's Avatar
geeze... I wish they would not do that.... one of the primary reasons engines are so damn expensive is due to engines that should be otherwise identical not being so, even though they all produce nearly identical power curves.
Old May 12, 2009 | 11:07 PM
crush02342002's Avatar
thanks for the heads up
Old May 12, 2009 | 11:09 PM
coryjames's Avatar
same with the xb2 if you need the cover i have 2 extra tc covers
Old May 12, 2009 | 11:18 PM
hey cory do you have any spare engines (without holes...lmao)
Old May 12, 2009 | 11:23 PM
coryjames's Avatar
lol the one with the hole has ben fixed i welded up the hole no leaks its on a non load bearing part i have that and a motor out of a tc that is un touched with 12000 miles on it the one with the hole in it it torn down to a bear block
Old May 12, 2009 | 11:36 PM
aight im coming over to steal one...lol...j/k id like to see what you might give one up for? just curious...around here at a junkyard they want atleast 2g's for a 2az out of a tc...____es me off
Old May 13, 2009 | 12:45 AM
coryjames's Avatar
there are a few here im working on one for todd they are about 750-1500 her pulled out ready to go with full harness ill see what i can find you crush
Old May 13, 2009 | 02:05 AM
dont really need the harness but hey extra doesnt hurt either...lol
thanx alot brethren...pm me if ya find something...btw how much is shipping an engine? prolly cheaper for me to pick it up...lmao
Halo19boy
Jan 27, 2015 10:19 PM
Ramroids55
Jan 16, 2015 02:42 PM
AdmirN
Jan 5, 2015 10:19 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
eric_m
79
Mar 17, 2013 12:21 AM
