P0335 Code After Underdrive Pulley Install....
Old May 11, 2009 | 07:57 PM
ChrisLilja's Avatar
Default P0335 Code After Underdrive Pulley Install....
Just finished putting my NST underdrive pulley on....got in the car started it up and got a P0335 CEL Code (Crankshaft Position Sensor ”A” Circuit Malfunction)
....Car seeeeeeeems to be running normal, why would this code pop up after this install - I did everything correctly as far as I know...What could have gone wrong or what would this change have to do with this code...
Car has been idling for 15 min + and no changes
I'M SCARED....
Old May 11, 2009 | 07:59 PM
ack154's Avatar
Don't recall seeing that before. Have you tried to disconnect your battery and reconnect it (to reset the ECU) and see if it stays off?
Old May 11, 2009 | 08:02 PM
ChrisLilja's Avatar
No.....Not yet ---- Would it be from mounting the pulley in correctly or something if it's not straight or something? (cuz i made sure it was flush and the keyhole was lined up)
Old May 11, 2009 | 08:05 PM
RA042726's Avatar
MN Scions
maybe reset the ecu??
might have to learn the new specs.
i have no idea to be honest, just throwing it out there
Old May 11, 2009 | 08:06 PM
RA042726's Avatar
MN Scions
sorry taht took me so long.
and for wondering if it's not on right, if you reset the ecu, and the light comes back on, then you know you actually have soemthing wrong
ack154's Avatar
As long as it was lined up and in there good, I don't think that would be a problem.
Only a couple results came up in the search and half were from boosted people running F/IC - so didn't apply to you.
It's possibly the sensor could be coincidentally bad. I believe they're pretty cheap actually. I think the one for my g/f's 04 Neon was under $20 or just over that price. And took about 15 min to swap. Can't imagine the tC is much more difficult.
Old May 11, 2009 | 08:07 PM
ChrisLilja's Avatar
What could possibly cause this.... I don't get what could have happened
....Car battery was just disconnected I'll go reconnect it in about 20 minutes
Old May 11, 2009 | 08:10 PM
ack154's Avatar
You don't really need to wait that long. A couple minutes should reset it no problem. Then just see what happens. No idea what the cause would be, but it is possible the CPS just went bad.
Old May 11, 2009 | 08:19 PM
KillaSpiceTSW's Avatar
Make sure to check sensor wires, belts etc.... It isnt common but Ive searched on google and found that even timing belts can throw a P0335 code. The most common issue I saw was a sensor that might be dirty and usually isnt broken. I dont really know... If you cant figure it out ill ask my bestfriend, hes a Mechanic. Good luck
Old May 11, 2009 | 08:21 PM
ChrisLilja's Avatar
Well it's a brand new pulley belt I just put on to fit with the Underdrive Pulley - How would this just coincidentally come on after I changed the pulley out...
Old May 11, 2009 | 09:05 PM
ChrisLilja's Avatar
Just went out and reconneted the battery and the light then turned off and no code was read....Still is very interesting to me how messing with just "hardware" like this threw a sensor code...but whatever it is gone now (I even drove it around a bit and everything seems fine *knock on wood*)
....In other news as I was putting my tire back on the car I noticed this
Looks like it's time for new tires....Any suggestions?
Old May 11, 2009 | 09:25 PM
ack154's Avatar
WHOA!
You need to not drive on that tire. Seriously.
What sort of tire you looking for? All season? Summer?
My god dude, lucky you didnt get a blow out.... Thats nuts. Get anything other then Wanli or Sunny Tires. Worst tires and money Ive ever spent in my life. Crappy Chinese tires with some fake compound, ewww. I like yoko and pirellis.
Old May 11, 2009 | 09:44 PM
ChrisLilja's Avatar
Yea....I didn't even feel it driving and I'm SOOOO glad I caught it before it got worse (on the road)
I was looking at Kumho Ecsta ASX. I heard they are great for the money and not crappy quality - I'm looking for some good All Seasons for the money right now (can't afford to have winter/summer tire sets at this time) and I live in Chicago with snow n such....
Old May 11, 2009 | 10:20 PM
RA042726's Avatar
MN Scions
about the code:
i had the same thing happen to me saturday on my way to the show. I bottomed out a little bit when I dropped off a fricken cliff on the highway (construction) and my CEL came on.
went to autozone to get it read, answer I got
"are you sure your light came on? I'm not getting anything"
so i disconnected/reset ecu and it went away.
he said sometimes there are just glitches.
oh well. gald you got it fixed. and let us know how the pulley goes, I've been thinking about getting one
Old May 12, 2009 | 03:54 AM
BZinn1's Avatar
it is possible the CPS was loose when you took off the belt and hit it just a littel,I am assuming you did not unhook m=batery so it may of goten a glitch in it and set off the code.......drvie it for a few days and if code comes back you need to replace sensor.......also get new tires before you wreck your car.......those are dangerous........
Old May 12, 2009 | 02:30 PM
cburglb34's Avatar
get bridge stone g-force radials they cost 125 each atr costco
Old May 23, 2009 | 11:05 PM
jazar07tc's Avatar
HAHA woah dude......did you just get your oil changed at the dealer and found that tire on your car? JK
That_Kid_Ju
Sep 30, 2015 10:05 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
wayneside
Regional - Southeast
Sep 23, 2015 10:42 AM
wayneside
Regional - Pacific Northwest
Sep 23, 2015 10:29 AM
Gigs
Sep 15, 2015 03:54 AM
