First Problem in years (white smoke of doom)
Old May 14, 2009 | 05:48 PM
olaHalo's Avatar
Default First Problem in years (white smoke of doom)
I finally ran into an issue.
The car is shooting white (im pretty sure its white not blue) smoke out of the exhaust
and also shooting it out of the valve cover breather thing.
If i pull the dipstick while the car is running, the white smoke comes out of the dipstick hole.
Also, My coolant level went down about 1 inch since yesterday, so im assuming that Im burning coolant.
Sounds like a Head Gasket issue?
Any and all suggestions are welcome and wanted
thanks guys
Old May 14, 2009 | 05:51 PM
beastC's Avatar
think you are right
Old May 14, 2009 | 05:55 PM
olaHalo's Avatar
Originally Posted by beastC
think you are right
i hope im right
head gasket it not really a big deal at all
rings, blowby or something else is what im worried about
jonathan110987's Avatar
mine did that when my piston rings went out.
Old May 14, 2009 | 06:00 PM
olaHalo's Avatar
so you had white smoke AND your coolant levels dropped?
if so, its time for that good ol motor build
Old May 14, 2009 | 06:21 PM
nodsetse's Avatar
Blown head gasket no big deal? I'd say that depends on how it blows. Have you checked the oil on the dipstick? Does it look normal or kinda like chocolate milk? If the latter, then water has mixed with the oil and there will be a lot more damage if continuing to run. Maybe you got lucky and the gasket blew such that the water isn't contaminating the oil, I certainly hope that's the case for your sake.
Old May 14, 2009 | 06:26 PM
youngflyer's Avatar
your rings are shot bud. white smoke coming out of the dipstick is a tell tale sign of blow by aka blown piston rings. do a compression check and post the readings but nore than likely your in for a motor build
Old May 14, 2009 | 07:49 PM
olaHalo's Avatar
thanks for the replies guys.
no, the oil from the dipstick looks normal
however on the valve cover hole, when the smoke comes out a little oil will come out too, and its milky.
but the oil on the dipstick looks perfectly normal, and my oil level is fine.
im planning on doing a compression test soon.
Old May 14, 2009 | 07:52 PM
TCpete's Avatar
compession check first.. if it reads ok then most likely your HG is toast which is not a big deal
Old May 14, 2009 | 08:50 PM
youngflyer's Avatar
white smoke from dipstick= not good
Old May 15, 2009 | 01:37 AM
FMTC08's Avatar
Old May 15, 2009 | 01:41 AM
ElevationTC's Avatar
keep us posted!
Old May 15, 2009 | 02:02 AM
crush02342002's Avatar
sucks mang...sorry to hear it
Old May 15, 2009 | 02:51 AM
RusWolf's Avatar
sucks... i ran into a problem on sunday as well that put me into short block core purchase and building motor by ERL.
Old May 15, 2009 | 06:17 AM
Ace83's Avatar
Ronin Scion
time to get build! but yeah compression test first but for now stop driving the car unless you got it figured out.. to me its like piston rings or HG
Old May 15, 2009 | 08:44 AM
olaHalo's Avatar
ya, either way.
im probably gonna throw some decent rods and pistons in there.
at least some good will come out of it.
yeah i will not be driving the car
instead ill be riding my bike with no license lol
Old May 15, 2009 | 08:46 AM
pwee08's Avatar
Originally Posted by ElevationTC
keep us posted!
dont meen to thread jack or w.e but where in orlando are you at im in winter park and i have yet to see a boost tC around here
Old May 15, 2009 | 11:12 AM
keep us posted!
I work right in maitland at the auto specialist next to rodgers corvette! stop over and take a look!
Old Jul 7, 2009 | 12:19 AM
olaHalo's Avatar
UPDATE
sorta lol
cars been sitting for 2 months
still havent got a compression test
i put the car back to stock (keeping the turbo though) and ill be doing a compression test asap.
BTW when i drained my oil it looked perfectly normal
Old Jul 7, 2009 | 12:21 AM
well thats a good sign atleast...lol
