Rear Seat Delete - Finished! Pics on page 3.
Old May 16, 2009 | 12:59 AM
CarbonXe's Avatar
Default Rear Seat Delete - Finished! Pics on page 3.
I'll be updating this as I make progress with my car. This will basically be the worst DIY ever, but it's very easy to make.
To cover all the technicalities, the rear seats weigh approx 60-65lbs, between the bench, seat back, head rests, hardware, seat belts, etc. That's not including anything under the stock cargo cover. If anyone wants to add that stuff up, feel free, but I'm not driving around without the stock subs, jack and spare tire.
I'm using about 1/4-3/8" thick plywood for everything, only costs about $12-$20 at Home Depot for a massive sheet that provides more than enough for you to ____ up a few times. I don't have any measurements, that stuff is pretty simple to obtain. And I don't really feel like explaining how we cut the top piece, just know that it took us about 25 tries to get those stupid curves right. We used the rear seat bench as a template for the shape, then just shaved off 1/2" after 1/2" until it was the right size.
It still needs a lot of work and nothing is bolted, in fact everything fell apart when I drove home. Once it's all done, it will be fully carpeted, and bolted to the car, using nothing but the stock bolt holes. This project will be 100% reversible, meaning no new holes will be drilled, no parts will be cut off, etc.
I should have more done later this week, since the weather is supposed to be much nicer than it has been. I still need to paint the wood to give it some protection from moisture, finish sanding everything down, and then carpet it.
Also, since the rear seats deaden A LOT of outside noise, I suggest putting down some sort of new sound deadener. I used 1 gallon of liquid eDead, and put it under the spare/subs, under the rear seats, inside the rear quarter panels and inside the hatch panels. It did a pretty good job deadening my exhaust, it basically compensated for the lack of the rear seats. I also just added this crap that I got from work. It's just really thick packing foam. Since it was pre-cut, I just shoved it inside there.
Old May 16, 2009 | 02:02 AM
Ro_Ja's Avatar
watching
DIY would be nice...
Old May 16, 2009 | 02:16 AM
yellowxhoodie's Avatar
you shoulda just made a template from cardboard. lol
im waiting on 1 more thing to come in the mails.
already purchased, ETA 2 weeks.
then ill make a yellowxhoodie DIY Rear Seat Delete. lol
Old May 16, 2009 | 02:21 AM
CarbonXe's Avatar
Yea you make the DIY.
If I made one, it would basically be..."remove everything. Make box. clean up." With just a start and finish picture. I always forget to take pictures along the way lol.
Hopefully I'll have this finished on Tuesday or Wednesday. I'm going to make a few cuts where it rubs in places that it shouldn't and give the thing a real good sanding. If it's not raining tomorrow, I'll even go ahead and just paint the whole thing and give it a few days to dry/air out.
Old May 16, 2009 | 02:30 AM
ack154's Avatar
I would totally do this if it was legal in my class. I'd have to run SM if I started removing interior. As it is I just fold my seats down so my center of gravity is technically lower... not by much... but technically.
Old May 16, 2009 | 02:36 AM
Big_Bird's Avatar
Im watching dees won
Old May 16, 2009 | 02:46 AM
Thorium06's Avatar
i wish the st classes allowed rear seat delete, or if the sm classes were on street tires. looks cool nonetheless, i want to dump mine
Old May 16, 2009 | 03:04 AM
scikotictc232's Avatar
how much lighter over the rear seat is it ? looks like if you are trying to cut weight you could have just done it by removing the rear seats/
Old May 16, 2009 | 03:21 AM
CarbonXe's Avatar
I'm not doing it to save weight. If I was, I'd have everything out of the trunk gone and wouldn't have put down the eDead. I haven't actually weighed anything that will be going into the car, but if I had to guesstimate...about 10lbs for the wood, 10lbs for the eDead, 3lbs for the carpet, and 2lbs for the foam. So about 30 lbs less than stock and it will be quieter.
The amount of weight that can come out of the interior is nowhere near worth the increase in road noise. If it was 400-500lbs, than yes, but at ~150lbs, it's not even a noticeable gain. The only thing that is noticeable, is that you'll go deaf within a week.
When it's all finished, it will serve as function and form.
Old May 16, 2009 | 04:49 AM
Joyride's Avatar
I helped with this project. I swear i did.
Old May 16, 2009 | 04:59 AM
Trogz's Avatar
watching this... I might try this and put subs in the box. Could this be possible?
Old May 16, 2009 | 07:33 AM
lol, ive had everything out of my car since day 1, so whoever reads my DIY will be on their own for that part.
and i dont really mind the road noise, i think it tolerable.
Old May 16, 2009 | 08:50 AM
ya my rear seat delete involves taking out the rear seat and leaving it. I have the trunk gone as well.
Old May 16, 2009 | 09:33 AM
rosedaleny806's Avatar
watching for failure haha jk can't wait to see it, jon.
Old May 16, 2009 | 01:57 PM
David616's Avatar
*watching*
Old May 16, 2009 | 02:49 PM
BlizZard's Avatar
Originally Posted by David616
*watching*
Old May 16, 2009 | 03:11 PM
CarbonXe's Avatar
I couldn't star the exhaust drone on the highway.
Old May 17, 2009 | 12:56 AM
tcridinclean's Avatar
1UP Crew
looks like very clean work so far, cant wait to see the finished product
Old May 18, 2009 | 01:07 AM
shupes31's Avatar
hmmmm I'd definitely like to do this.
Watching for awesomeness.
Old May 18, 2009 | 05:53 AM
davedavetC's Avatar
about damn time, did you guys end up using the construction paper? lol, if you did mail me the templates so i can do something similar.
did you end up making it able to be used for storage? or did you scrap that idea?
