Ballast help
Old May 17, 2009 | 04:20 AM
jj90011's Avatar
Default Ballast help
Hey
Everyone i have been searching for a ballast for my anzos because it was melting on me for my headlights due it rubbing against the frame . the serial number for it is
RN0581V
Can anyone please direct me to the right place in finding this . i have searched like crazy on here and on ebay and no luck.
Thanks in advanced.
Old May 17, 2009 | 12:48 PM
jasongawlik0313's Avatar
use any ballast you want theyre universal i have eagle eyes its the same company and i have 3 sets of hids just a normal 9006 connection and the +/- to the bulb just make sure you order the right wattage i think the stock anzos are 35w ballasts
Old May 17, 2009 | 06:26 PM
Yanki01's Avatar
good digital ballast right here...
http://www.retrosolutionsllc.com/ser...VERSION/Detail
Old May 18, 2009 | 05:04 PM
jj90011's Avatar
- jasongawlik0313
Im not sure if its the same one where talking about . i dont know if you have seen the little rectangle block located on the bottom of your headlight housing. Thats what was melting i removed it from the bottom of the headlight to keep it from melting . it has two cords on one end a blue and green and the other end has 4 or five cords also . i will take a pic of it when i get home so i can clerify what im talking about .
Old May 20, 2009 | 05:16 AM
jj90011's Avatar
alright i found these pics this is exactly of what i need except its a different serial number
Old May 27, 2009 | 11:02 PM
AcidDrop's Avatar
that's the transformer for the halos, try one of the ozniums cold cathode transformer and see if that works.
Old May 28, 2009 | 03:30 AM
ScionJim23's Avatar
god that's a scary wiring job...lulz
Old May 28, 2009 | 03:41 AM
jj90011's Avatar
thanks acid drop.
I had figuered it out the day before your post i bought a cold cathode off a 2001 bmw m3 series and it worked like a charm the wiring was not so bad i replaced both headlight cathode just incase the other one burned up .
Old May 28, 2009 | 05:32 AM
AcidDrop's Avatar
that's cool, good to hear you where able to fix the problem.
mischman
Sep 15, 2015 03:38 PM
Clayton1
Feb 8, 2012 06:11 AM
Greg2385
Scion tC 1G ICE & Interior
12
Mar 11, 2007 12:02 PM
houstonBB
Feb 16, 2007 07:17 PM
dieselstation
Scion tC 1G Aero & Exterior
23
Jan 20, 2007 08:43 PM
