cheap lugs ruined my day
Old May 19, 2009 | 03:53 AM
biancoxb's Avatar
Default cheap lugs ruined my day
I picked up a chrome lug kit from my local autozone and installed them a few months ago. Today I noticed rust was getting unusually high on them so I decided to go back to oem. After removing all , when I got to the last wheel in the rear I was torquing the first bolt and it snapped the stud and lug right off! I tried the next and it literally crumbled, I wd40d the next two and they snapped off like twigs. Never seen anything like this before and was beyond shocked. I ran back to autozone and spoke to the manager. I had a receipt with kit and he told me it wasn't Autozone's fault. I didn't step on the lugs, and I demanded my money back ($30) and they refused. So After hammering away at the rear drum for hours I finally got the rear drum off and replaced the studs that I went and got from Pepboys. Was just very confused about Autozone, would you say a problem like that is customer's fault or the store?
Old May 19, 2009 | 05:40 AM
jcs_xb's Avatar
its not the customer's fault and i wouldnt say taht it would be autozone's fault as well. i would say that it would be the manufacturer of the lug nut's fault.
it's like going to gamestop and blaming them for your xbox for malfunctioning.
they would tell you to call microsoft and ask them for help.
so my advice to you is call up the people that made the lugs and ask them for a refund, and i am sorry to hear what happened.....
hope that answered something for you...hahahaha (just my two cents)
Old May 19, 2009 | 03:09 PM
MadMike550's Avatar
it shouldnt take you hours to get your drum off....
that sucks that tyhat happened to you...did you go with the stock length studs?
if I had to get new ones I would go with longer ones
Old May 19, 2009 | 03:24 PM
biancoxb's Avatar
I ended up getting stock stud sizes, The rear drum just would not move with the hammer, eventually I just started giving it all hell and it popped off finally. Going to give the manufacturer a call today. I took some pics of the damage before I fixed it. I'll post em soon.
Old May 19, 2009 | 03:29 PM
MadMike550's Avatar
if you look at the rear drum there are 2 threaded holes
you can screw bolts into them to help get the drum off
also there should be an acess slot in the back of the brake plate..where you can adjust the rear shoes..much easier if you loosen them first..and do not keep you emergency brake on
Old May 19, 2009 | 10:26 PM
OakToddler's Avatar
What brand name are the lugs from autozone?
Old May 19, 2009 | 11:24 PM
Sciond's Avatar
a good reason to spend for Rays...
Old May 20, 2009 | 12:42 AM
swartzautoman's Avatar
this can be from several factors.
is always importinat to properly torq the lub nuts.
i think the xB is only like 80 ftlbs
any time you take them off clean them out befor putting them back on
Old May 20, 2009 | 01:03 AM
vettereddie's Avatar
Gorilla Lugs are about 1/4 the price of Ray's and work just as well. I'm not paying more for lugs then I did for each rim.
Also, whenever you pull the lugs, this really helps them from rusting again:
http://www.permatex.com/products/Aut...ubricant_a.htm
Old May 20, 2009 | 01:56 AM
OakToddler's Avatar
Rays are very soft metal....
I like my gorrilla locks....pretty cheap on ebay.
jct's Avatar
jct
at the tire shop they'll clean off all the lugs that you anti-seized up and goes down the drain :-\
Old May 20, 2009 | 02:37 AM
Yeah, I don't go to tire shops to let them put the wheels on. I bring them in off vehicle, less chance of them scratching them that way.
As for the anti-sieze, one bottle is a lifetime supply. My dad has been working on cars since 1968 and I swear he's used the same jar of it since then. The lettering is worn completely off but there's still stuff in it.
Old May 20, 2009 | 02:40 AM
Sciond's Avatar
80 is correct I hand torque everything....
Old May 20, 2009 | 02:41 AM
Sciond's Avatar
gorilla is good I just like Rays style
Old May 20, 2009 | 03:11 AM
yep, hand torque is the best way
Old May 20, 2009 | 03:25 AM
OakToddler's Avatar
Rays are also the really light ones, I think.
I'd like to have them.
Are you people closed nutted or open?
I need open lug because of the wheel cap that goes over the lug nuts.
SPLINE seems very nice, too.
Old May 20, 2009 | 01:17 PM
TypeX's Avatar
Rays lugs + Stock wheels = incorrect seating
To the OP, i think i met you at the Circuit city meet right?
You had the white box with the spacers?
I've got the camo box on sleds
If you ever need any help or whatever hit me up
Old May 21, 2009 | 03:16 AM
Sciond's Avatar
pf course why would you use tuner tuner lugs on stocker's...he has BSA 17's
Old May 21, 2009 | 03:27 PM
biancoxb's Avatar
thanks a bunch TypeX, ya that was me. I am back on stockies with the original open lugs and have a fear of aftermarket lugs lol. I;ll get over it haha
Old May 22, 2009 | 05:08 PM
TypeX's Avatar
When i met him the other day he had steelies n hubs (sorry for the confusion!)
