Crower Cams Caution
Old May 20, 2009 | 06:19 AM
Windu's Avatar
Default Crower Cams Caution
Since I got my motor back in the car I have been chasing a cam sensor error. Caused my aem not to establish a stat sync resulting in a no start condition with the standalone. So I pulled it out put the e-manage ultimate back in. Now it would run but had hard starting issues and was popping a check engine light for the cam sensor. The signal was good above 1100 rpm, but if rpm dropped below that it would throw a code. Pulled that off and went back to stock injectors and ecu. Same as with the ultimate.
I checked the harness, it was good. Threw a new sensor at it, didnt fix it. So I pulled the valve cover and found that the three pins on the end of the cam were set too far from the mag pickup sensor. Using a punch and hammer I was able to set the distance from the pickup close enough for the ecu to get a good signal at cranking speed. Problem fixed.
So if you buy a set of cams or have your stockers out for any reason, check this before you get it all back together.
Old May 21, 2009 | 05:08 PM
09TC5M's Avatar
Do you have dyno results for the Camshaft?
Old May 21, 2009 | 05:43 PM
DezodDon's Avatar
Seriously??? The man just helped the entire community by solving a serious problem and you ask for dyno numbers......wtf
Thank you Rob for posting this information......... if you see my other thread asking who runs the AEM EMS and aftermarket cams, this was the information I was trying to get out of people to see if this was indeed the problem as it seems we were both hot on the same trail. I'm glad that you found it out. You are very attentive to detail. I like it. Good work!
Old May 21, 2009 | 07:26 PM
09TC5M's Avatar
It was just a question. There is very little published dyno data for the Crower Cams.
Old May 21, 2009 | 07:42 PM
paul_dezod's Avatar
Scionetics
KAD
Don't mind Don. He is just upset due to the large amount of pizza he ate for lunch.
paul_dezod's Avatar
Scionetics
KAD
Default Re: Crower Cams Caution
I am glad Don and you where able to get it all nailed down.
Old May 21, 2009 | 08:22 PM
09TC5M's Avatar
Its all good, I never take those things too seriously. There are quite a few things that I have been interested in. One is your new Hondata type ECU controller, and the second is the Crower NA Cams. I have e-mailed BC several times about dynos. The last response I got said that is was about 20 WHP with supporting mods, when I asked for the dyno sheet they never responded. I just e-mailed them again a few mins ago. I'll just have to wait an see what happens.
Old May 21, 2009 | 08:28 PM
paul_dezod's Avatar
Scionetics
KAD
The problem with the type of mod like cams is that the power levels are HEAVILY reliant on the type of supporting mods AND tuning. For example:
Car 1: N/A
Intake
Header
Exhaust
Standalone Engine Management
S2 Cams
Car 2: N/A
Intake
Header
Cams
Assuming good tuning, car 1 will typically make more power.
Old May 21, 2009 | 08:34 PM
09TC5M's Avatar
Yeah I had assumed that but a lot of people will not buy expensive parts without some sort of proof. I see it all time on here, like with the UNICHIP.
All were asking is for BC to release some Dyno results. We may or may not have all of the supporting mods used on their test car, but atleast we will have an idea of what is achievable with the new part(s).
Old May 22, 2009 | 02:38 AM
Windu's Avatar
A BIG thank you to Paul and Don from dezod for all your help with bouncing ideas around to figure this out.
The only dyno numbers I have are with the e manage ultimate. With a conservative tune, 11:1 A/F it made 240 hp on my superflow with 6 psi. If I get the rest of the bugs worked out of the new set up this weekend Ill get it on the dyno again next week.
Old May 22, 2009 | 02:50 AM
Windu's Avatar
Old May 22, 2009 | 01:43 PM
paul_dezod's Avatar
Scionetics
KAD
You're very welcome. Don and I where discussing it being a problem with the cams. and Don was Ace Ventura enough to see it through. Glad all is well.
Old May 22, 2009 | 03:43 PM
09TC5M's Avatar
Thanks for posting the graphs Windu
Old May 24, 2009 | 04:21 AM
09TC5M's Avatar
I got a response from Dustin at BC. He said the dynos should be up soon for the stage 2 NA cams. He also stated that they have made 18-20 hp on the cams but it requires an ecu tune to get the most out of them. He didn't specify if the hp was at the wheels or crank.
steeze69
May 24, 2021 02:57 AM
gedster314
14
Nov 17, 2018 02:56 PM
MisterSkiz
Sep 27, 2015 10:25 PM
Topfueltom69
Sep 6, 2015 05:25 PM
