HKS TURBO TIMER..DIY PLZ?
Old May 21, 2009 | 08:14 AM
Mrsanchez925's Avatar
Default HKS TURBO TIMER..DIY PLZ?
does anyone know how to install a TT?
if so could you explain how?
and also,
do i need a special harness for it?
Old May 21, 2009 | 08:59 AM
SquallLHeart's Avatar
http://www.hksusa.com/faq/?ID=1647
Old May 21, 2009 | 09:42 AM
It doesnt quite show which Wires are which for the TC tho.
but ill look a bit more. i usually tend to not catch stuff the first time around.
thanks tho!
Old May 21, 2009 | 10:19 AM
the instructions tell you to call them.
Old May 21, 2009 | 07:12 PM
FLIN-SCION's Avatar
PTuning offers a harness for $20. Is this type 0 or 1? If its type 1 then you need to hook up rpm, speed, ground and E-brake lines
Old May 21, 2009 | 11:37 PM
gingles's Avatar
its the blue and red wire under the steering wheel i believe...there is a diy on here already................SEARCH......................
https://www.scionlife.com/forums/vie...dy+turbo+timer
Old May 24, 2009 | 06:56 PM
RusWolf's Avatar
i bought Ptuning harness didnt get a chance to try to install my type 1 yet.. hopefully its simple.
Old May 26, 2009 | 11:20 AM
yeah i ordered the ptuning harness also... im just waiting to get it now...
Old May 26, 2009 | 04:10 PM
dave2610's Avatar
i just ordered the harness as well. could one of you take pics where it plugs in
Old May 26, 2009 | 10:55 PM
ptguy08's Avatar
hey so heres a question...i have the apexi turbo timer. and i cant figure out how to get it past the 1 minute setting. the online instructions on their website are hard for me to understand...do i even need it past 1 minute?
Old May 27, 2009 | 03:31 AM
gingles's Avatar
no ptguy.....our oil temp is weird......i have mine set at 40 seconds now.......if the oil is above 200 degrees ill do 50 seconds....our oil takes so long to cool and it has a high operating temp
Old May 27, 2009 | 11:29 AM
ptguy08's Avatar
thanks man! much appreciated!
Old May 27, 2009 | 10:00 PM
dave2610's Avatar
so you only need to set the timer to 1 min?
Old Jun 2, 2009 | 08:18 AM
So is it easy to install once u get the Ptuning wiring harness??
is it all PLUG N PLAY
or do u still have to do some wire splicing and connecting?
Old Jun 2, 2009 | 04:46 PM
dave2610's Avatar
Its pretty much plug and play. i only had to tap the e brake wire. Depending which timer you got you also might have to tap the vss wire
Old Jun 2, 2009 | 06:18 PM
I have a HKS TT , but im not sure if its a type 0 or type 1 because i bought it used... arg!!!
Old Jun 2, 2009 | 06:39 PM
dave2610's Avatar
im pretty sure the back light on the type 0 is red and the type 1 is blue.
Old Jun 2, 2009 | 07:44 PM
CarbonXe's Avatar
The HKS Turbo Timer Type-1 offers all the features of the Type-0, PLUS several monitoring and measurement tools. Vehicle speed and RPM can be displayed on the Type-1's LCD monitor and a speed warning level can be set. A 2 stage RPM warning can also be set and used as a shift light. When a warning level is reached the Type-1's LCD monitor will switch from blue to red and an audible beep will sound.
The HKS Turbo Timer Type-0 is a basic turbo timer that features an auto mode that adjusts engine idle time according to the most recent driving pattern, multiple preset times, audible alarms and a volt meter. The easy to read back-lit digital LCD display flashes between orange and red during the countdown The Type-0 is ultra compact, less then a 1/4 din in size and available in a black or silver case.
For the warning system:
Type 0 = Orange/Red
Type 1 = Blue/Red + Audible beep
http://www.hksusa.com/content/pdf3561.pdf
Old Jun 14, 2009 | 11:07 PM
weezyfbayba's Avatar
some one make a hks DIY not the greddy
Hydryman
Feb 23, 2016 03:35 PM
tckid21
Jan 9, 2016 09:19 PM
brett561tc
Sep 15, 2015 06:33 AM
mxwes
Aug 30, 2015 09:11 PM
Angelj85
Aug 18, 2015 01:27 AM
