help, Grinding Noise when slowing down, using brakes
Old May 24, 2009 | 12:26 PM
ValenciaS's Avatar
Default help, Grinding Noise when slowing down, using brakes
I have a 09 tc with 9,6XX miles on the car. I just started to notice when i slow down with my brakes I here a loud grinding noise. I have noticed when I put my car in neutral to stop I cannot here the noise. But if im downshifting and using my breaks I can here the noise.I do have a turbo kit on the car so Im not sure if I should take it off and bring it to the dealership. Or if this issue is normal on our cars. The car was running fine, I have had my kit on the car for about 2,000 miles. I would appriciate the help.
Old May 24, 2009 | 01:55 PM
Ace83's Avatar
Ronin Scion
if it not you brakes, check you rotors! and check for some wheel play could be a bad wheel bearing
Old May 24, 2009 | 02:07 PM
ValenciaS's Avatar
its really loud lol , the weird thing is the car was driving normal. I was working on the car and only thing I did was replace my wastegate with a new one. When i started her up i noticed when i brake its a loud grinding noise. Seems to be comming from the drivers side. Car boosts fine and runs strong. Hey ace im at work at the moment. I will check that when I get off. Thanks for the support and help.
Old May 24, 2009 | 02:16 PM
ValenciaS's Avatar
How can I check for wheel play.
Old May 24, 2009 | 02:28 PM
Ace83's Avatar
Ronin Scion
jack up the car, with the wheels of the ground.. try to grab opposite sides of the wheels and try to wiggle it back and forth.. if there is a play its likely a wheel bearing.. when wheel bearing goes bad the calipers is likely to rub against the rotors and gives a really loud grinding noise.. and oh its only when you brake right not on hard deceleration or engine braking?
Old May 24, 2009 | 03:34 PM
TRDIZZLE's Avatar
do you brake boost?
Old May 24, 2009 | 03:59 PM
ValenciaS's Avatar
I do not break boost , and yes ace also when i use the gears to decelerate(and not using the brakes) I can notice it
Old May 24, 2009 | 04:02 PM
ValenciaS's Avatar
also could this be cause i did not get an allignment after i installed my h-tech springs ?
Old May 24, 2009 | 04:06 PM
SW_08's Avatar
you might have some debris in between your rotors and pads....just powerwash it and see if something changes....
Old May 24, 2009 | 04:12 PM
ValenciaS's Avatar
i just find it odd, It has been raining here for 1 week and 3 days straight that could be why.
Old May 24, 2009 | 04:13 PM
SW_08's Avatar
yea it might just be the rust....
Old May 24, 2009 | 05:39 PM
ValenciaS's Avatar
Is it safe to pressure wash the whole bottom of the car ? Control arms/ suspension ect..
Old May 24, 2009 | 06:32 PM
Ace83's Avatar
Ronin Scion
is it like an on and off vibration/deep buzzing sound that you cant hear when the windows are rolled down and that disappears when you coast the car to neutral? you have an upgraded clutch?
Old May 24, 2009 | 06:55 PM
InfideL's Avatar
if its bad wheel bearing you should be able to hear it when you make a turn
Old May 24, 2009 | 06:56 PM
Ace83's Avatar
Ronin Scion
^^ i agree, it more on grinding sound when turning and disappears at times with some braking
Old May 25, 2009 | 01:25 AM
ValenciaS's Avatar
Hey guys , I just changed my oil today , I was running Mobile 1 5w20 and I used 5w30 now and the noise when away. Also I reinstalled my dezod turbo back exhaust. I was runing from the s-pipe(couldnt take the noise any more) But the car is running perfect. Thanks for the support guys.
ffodge
Apr 25, 2015 07:03 PM
Raiders757
Apr 14, 2015 10:26 PM
PrettySenshi
Apr 13, 2015 05:21 PM
jtucker7
Apr 8, 2015 05:41 AM
Joeynenj
Nov 25, 2014 05:29 AM
