spark plugs
Old May 25, 2009 | 07:01 PM
goodguy889's Avatar
Default spark plugs
which is best for a s/c with the 9.5 pulley. the information thread said denso ik24 and i see a lot of spark plugs that are out so in ur guys opion which is best?
Old May 25, 2009 | 07:04 PM
scikotictc232's Avatar
glad to see the fenders are on. looks good man. how did the other side come out ? Im not sure on the spark plugs for the supercharger.
Old May 25, 2009 | 07:32 PM
goodguy889's Avatar
no not yet im gonna have to sand both of them and re-clear them. hows the turbo coming. and not to get off topic still need peoples input
Old May 25, 2009 | 07:50 PM
Spark Plugs, TRD Denso K22PR-U
Thats what I have mostly seen people run. Those come with the supercharger kit don't they ? turbo kit is coming a long slowly. trying to save up for school first than finish it in august. engine is going back to stock. Ill slap everything on before I take off.
Old May 26, 2009 | 02:27 AM
gompka's Avatar
1 step colder than stock, either brands should work, denso iridium or ngk is an upgrade to the trd ones.
Old May 26, 2009 | 03:56 AM
gingles's Avatar
bkr6eix is stock......bkr7eix is one step colder.....id go with the 7eix's
Old May 26, 2009 | 09:38 PM
NVMyTc's Avatar
X2
this is what I ran (after having lots of Spark plug problems w/ other plugs) and this is what all my other boosted guys/girls in my club run. Awesome plugs
Old May 30, 2009 | 03:58 AM
BlackKnight's Avatar
Music City Scions
I was told by a lot of FI guy not to run Iridium plugs anymore and switch to copper with .028-.032 gap. I am running NGK one step colder than stock which is heat range 7 copper plug. I was told even though Iridium is suppose to be better it takes a little more to push the spark through then copper. Like I said I don't know this is what experienced FI guys have told me so I plan on using them not to mention the price difference. I understand that Iridium's will last longer but with FI both will have to be changed early anyway.
Old May 30, 2009 | 04:02 AM
TheFantasticG's Avatar
I use the NGK Iri. 2step colder. No problems here. But I gap between .26-.28
Old May 30, 2009 | 04:26 AM
gingles's Avatar
hey black....ive also heard that and my roomate used to run copper plugs......you have to change them at every oil change as well....needless to say he switched to iridiums and hasnt complained.
Old May 30, 2009 | 05:01 AM
Music City Scions
If you are changing plugs that often something isn't right. Depending on oil change intervals I would change them every 3rd oil change. I get your point about them and I may try to go back to them after engine is broke in and tune is redone.
Old May 30, 2009 | 05:03 AM
gingles's Avatar
it depends on how much boost you are running.....high pso you have to change them more often. i just asked my roommate and he changed them every 5k miles on 12 psi
Old May 30, 2009 | 05:20 AM
Troys_tc's Avatar
NGK BKR7E, its an NGk copper plug that is one step colder, its chheap, and works great
Old May 30, 2009 | 05:26 AM
Troys_tc's Avatar
HTe iridium plugs a pre gapped, and your not supposed to gap the them, possiable surface contamination
Old May 30, 2009 | 05:30 AM
gingles's Avatar
ive gapped every iridium plug ive ever bought and never had a problem.
Old May 30, 2009 | 07:07 AM
Music City Scions
The reason they tell you this is so you won't gap the plug and take the risk of breaking or damaging the iridium tip. If the spark plug fails after you gap it causing engine damage they are no longer responsible since they warned you. Iridium tips are very sensitive and are very easy to break if not gapped carefully.
Old Jun 7, 2009 | 05:23 PM
jwaggz82's Avatar
good god - ive never heard of people changing out plugs every few oil changes or whatever. Dunno. I found this post and after 60k miles I am looking to change out plugs. If my compression/leakdown tests are ok im going to get the s1 dezod kit. I have 36k miles on my engine. Should the plugs be different on a FI setup opposed to a non FI setup? There is no way im wanting to swap them all the time so someone please help - thanks.
Old Jun 8, 2009 | 06:23 AM
Music City Scions
Yes it is different. It also depends on the plugs you use like I said from experienced people have told me to use copper plugs and not iridium. I have been told to change the copper plugs out every three oil changes 15k only because of my setup.
MeDizzy
Oct 8, 2015 03:31 PM
Renuco612
Sep 16, 2015 09:01 AM
BlingSlade
Sep 5, 2015 08:52 AM
