Dezod exhaust installed=bad rattle HELP
Old May 27, 2009 | 10:05 PM
foretwoone's Avatar
Default Dezod exhaust installed=bad rattle HELP
Installed my Dezod S pipe back last night, everything seemed fine. Started it today and there was a low rattle on idle. Now after 30 miles or so im getting a really bad rattle on idle and a little knocking around. Everything is super tight and all hangers are in. All pipes are fitted together fully. Anyone else with this issue or suggestions.
Old May 27, 2009 | 11:54 PM
mbaledge's Avatar
tC squad
Did you reinstall the little cross beam that goes across the resonator? If you did, that's where I'd put my money.
Old May 28, 2009 | 05:32 PM
BlckdOutTC's Avatar
yeah just take that off, or it could be rubbing against some heatshield towards the rear, in which case i removed the shield and took a hammer to it
Old May 29, 2009 | 02:45 AM
sm0k3n's Avatar
there is a heatshield right under your shifter on the mid pipe, right where it connects to your s-pipe, where your catalytic converter was there is a little bolt remove it, and take the heatshield off too... mine used to do the same thing, when you are stopped it rattles like siht
Old May 29, 2009 | 05:29 AM
foretwoone's Avatar
K i'll check those things out once my back recovers. I worked on this thing without a creeper and now my shoulder blades are killing. Also would it be wise to have a shop tack a few welds on the connections? I notice my tip is drooping because the clamps dont hold the muffler perfectly tight. i doubt anything can come off but things gotta get held tighter.
Old May 30, 2009 | 11:11 PM
sm0k3n's Avatar
Yea why not
Old Aug 13, 2009 | 07:32 AM
GamePlayerM90's Avatar
OMG! That F**King ____ed me off! But I finally got it to not droop...I hope. What I did was loosen the clamp that connects the muffler to the rear corner piece then position myself right under the connection and push them together nice and tight, to my surprise it was really loose until I did that and now it doesnt droop!
Sorry if this was long or if its confusing, just to summarize it.
Make sure the corner pipe goes practically all the way into the muffler till it hits the bend in the pipe then try tightening the clamp again. And if it still droops it might be the position of the clamp so just shift it around, but make sure the pipe is in deep.
Ok so that wasnt really a summary =)
Old Aug 13, 2009 | 07:36 AM
Go4shoped's Avatar
... or get it welded. lol. should be under $75.
Old Aug 13, 2009 | 08:25 AM
Smile
Dont want to get it welded in case you have to take it off for inspections or for legal reason (aka dick cops) or if you sell the car.
Besides my way was FREE
Old Aug 14, 2009 | 02:36 AM
Go4shoped's Avatar
i guess thats a jersey thing.
Down here in Florida cops wont bother you unless its crazy loud or if you're rocking a canister. I've had my car inspected once. It was for insurance. Yes, my exhaust is insured. lol
And my way would be free too since i have my own welder :D
Old Aug 14, 2009 | 07:35 AM
well good for you! smart ___.... haha jk
Well today it kept coming loose a little after driving a bit. Just tighten the bolts till you hear something crack, dont worry its ok
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
minter66
Dec 15, 2014 01:45 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
deathcabforme
Oct 29, 2003 05:23 AM
