LOCK
Old May 31, 2009 | 08:16 PM
7thgear's Avatar
Default LOCK
lock
Old May 31, 2009 | 08:28 PM
Andrew1782's Avatar
You open your hood. Then it will be fairly obvious. Not trying to be a jerk but have you done that yet?
Old May 31, 2009 | 08:29 PM
SW_08's Avatar
open your hood...
theres 4 clips holding it down...two on each side...u have to push done in the middle for it to pop and you can take them off....its two peices btw
you also have to remove your wipers....and then just pull it out towards you...just dont pull to hard simply b/c there are some type of clips holding it down in the back of your windshield....
hope thats helps
Old May 31, 2009 | 08:31 PM
frame's Avatar
you'll need to remove your wipers and then pop the hood open the there should be push pins that you will need to remove to the whole thing out.
Old May 31, 2009 | 08:33 PM
frame's Avatar
follow the instruction on this pdf. it is for removing the wiper motor assembly but also shows you how to remove the hood cowl.
http://zoltiz.com/cars/tc/files/tccowl.pdf
Old May 31, 2009 | 08:41 PM
7thgear's Avatar
ok thanks guys. i did open my hood, but i never knew about removing the wipers. that's why it wouldn't come off.
BZinn1's Avatar
yep that about explains it all......the secret to putting it back in is to make sure the tabs go under the windshield also when you put it back in or the rattle from it wil drive you nuts at stoplights.
user9430961
Sep 24, 2015 01:09 PM
black_toaster
Sep 18, 2015 06:16 PM
user9430961
Sep 15, 2015 03:16 AM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
BlingSlade
Sep 5, 2015 08:52 AM
