ok, bout to get a CAI few questions
Old Jun 2, 2009 | 01:13 AM
krazyjvilled's Avatar
Default ok, bout to get a CAI few questions
im about to get that injen intake that is on sale... few quick questions:
1. I recently bought a KnN air filter... will this have to be pitched in order to install the CAI, basically making that a useless buy? or does that stay in with a new CAI?
2. once the CAI is installed, or afterward, do i need to do anything with the ecu? if so, what do i need to do?
3. is it an easy enough install if i have a friend who is very car competent help me out?
thanks guys
Old Jun 2, 2009 | 01:15 AM
breaux_tC's Avatar
1. if it was for your stock intake then yes
2. no
3. no
Old Jun 2, 2009 | 01:16 AM
ack154's Avatar
1: Yes, now useless - except you might be able to sell it.
2: After it is installed, you will need to disconnect the negative of the battery, wait a few minutes, reconnect. Then start the car and let it idle for 10-15 min.
3: Yes.
Old Jun 2, 2009 | 01:17 AM
DJ08tC's Avatar
1. If the k&n was for the stock box it is useless.
2. wont have to do anything to the ecu as far as tuning if that is what you are asking
3. there is a thread on here where kids installed one, so yes it is easy
Old Jun 2, 2009 | 01:21 AM
BZinn1's Avatar
basically disconnect battery.
undo wire to MAF
undo MAF
take out old air box,disconnect from throttle body
I find it easier to install CAI by taking off front bumper,so do some don't.......
I also find it easier to instal Injen by undoing the fender bolts and moving fender out jsut like 1/2" to clear the bracket ont eh CAI as you push it through,you can dent fender pretty easy,thin sheet metal and big pipe with bracket right up against it.
once it is all back together hook battery back up and run motor for 5 minutes,no revving.......then take a gentle drive........gentle........then it should be good to go.....ECU will relearn most of its new flow rate during the idle and drive.
Old Jun 2, 2009 | 01:24 AM
ok, one person said to disconnect the battery then let the car run idle after connecting it again....
is this necessary? wouldnt the ecu fix itself once i drive around a bit or no?
Old Jun 2, 2009 | 01:27 AM
breaux_tC's Avatar
it did for me
Old Jun 2, 2009 | 01:28 AM
BZinn1's Avatar
anytime you take apart a electrical part on a 12v system unhook the battery.
but no the ECU will throw a code if you do not reset the ECU by unplugging battery.....also not unhooking the battery you risk blowing the MAF when you unhook,the chance is slim but it can and will happen.........do it right the first time and you will not need to buy new parts when it goes wrong.
Old Jun 2, 2009 | 01:29 AM
liltofuboix's Avatar
1. Is the knN air filter a drop in? if so it has no use for the cai becaus eit uses a cone.
2. No you don't need to reprogram anything.
3. Its easy except tedious. Your friend must know alot of stuff about cars. If not set aside about 3 hours or so.
Old Jun 2, 2009 | 01:31 AM
BZinn1's Avatar
even the instructtion manual you will get with the CAI will tell you to unhook the battery.......lol.......I give up trying to help...........
Old Jun 2, 2009 | 01:33 AM
^ listen to the man! hahaha. unfortunately i did not. but its cus nate, erik, and dan said i didn't need to when they were helping me
Old Jun 2, 2009 | 01:37 AM
thx guys... one last thing, tho it probably wont make a difference in my getting the cai....
some say the gas mileage improves a bit, some say its no real difference, others say its a slight decrease....
any opinions from anyone who owns one? and injen was proven to be the best cai of the group correct?
Old Jun 2, 2009 | 01:39 AM
hey man i didnt need to disrespect you at all... i was just trying to get a consensus... im completely new to all of this and just trying to do things right... everyone agrees with you and i will do precisely that
thanks!
Old Jun 2, 2009 | 02:28 AM
SuperWhite06tC's Avatar
Default Re: ok, bout to get a CAI few questions
thanks guys
1. Remove it. Sell it.
2. Disconnect battery.
3. Sure...
This may help, https://www.scionlife.com/forums/viewtopic.php?t=261572
Old Jun 2, 2009 | 04:06 AM
can someone tell me if they have ever had any problems with water getting sucked into the injen air take?? when it rains or going over puddles?
Old Jun 2, 2009 | 04:20 AM
BZinn1's Avatar
no worries......water in the intake only if puddle is as high as the filter to submerge.
just remember the best way to burn up anything sensor wise is to unhook while still energised.DC currant takes very little to screw stuff up in a car.
After reading thread after thread on here about person unhooking this and installing that with battery installed still and it is the end cause of the part failing always unhook battery first just to be safe.It is harder to blow the main fuse from battery to distro box than any other fuse in the car.
the ECU will learn without being unhooked but most the time it throws a code so may as well just unhook and start fresh and safe.
Old Jun 2, 2009 | 04:39 AM
ok cool thanks... so just unhook the battery while im installing... then plug it in and let it sit in idle for 10 minutes before drivin correct?
Old Jun 2, 2009 | 04:41 AM
i mean do i have to unplug the wires to the MAF the ecu like someone above said?? or just unplug the battery?
Old Jun 2, 2009 | 04:54 AM
o wait that was u lol... so disconnecting the battery isnt good enough then
Old Jun 2, 2009 | 06:00 PM
Yanki01's Avatar
Remove the negative from the battery before installing it. Google a how to, there's a good one with a couple of kids installing a CAI on a scion.
