View Full Version : Dread Wheel Hop
pkoule
01-19-2005, 02:00 AM
Among the less endearing behaviors exhibited by my xB is a disconcerting tendency for the front-end to hop under accelleration in low-trraction conditions. This is noticeable with traction control turned off in the wet from a standing start.
The xB is pure stock, 15" steel wheels, stock goodyear tires..and its TCM, if that matters :wink:
Aside from putting my lead-foot on a diet, has anybody got a cure for this?
scion1616
01-19-2005, 02:08 AM
Yes, leave the traction control on. That is what it was made for.
hotbox05
01-19-2005, 07:23 AM
even with traction control i get wheel hop , but then again i drive like i'm retarded sometimes lol
unlmtdndeavor
01-19-2005, 09:51 AM
its a fwd. theres gonna be wheel hop with the stock tires. if you want no wheel hop, upgrade to stickier tires. if you don't want to spend money, then u might want to change ur driving habits. u say u get wheel hop in low traction conditions....are you trying to get off the line quickly? if you are, try slipping the clutch a little bit. or warming up the tires first.
firesquare
01-19-2005, 10:02 AM
the Good years as called bty the automotive world
the screamin' eagles
Ashe_WCM
01-19-2005, 12:42 PM
Heres a thought, when you start to get wheel hop back off the gas till it stops.
thats the only thing that will really make a difference outside of new tires.
Tamago
01-19-2005, 01:06 PM
wider tires help too..
superjeer
01-19-2005, 05:06 PM
yeah, I get real bad hop in snow and ice. I can't remember if I had it with my other wheels and tires. I think I did though.
TheScionicMan
01-19-2005, 06:27 PM
What he said... :wink:
llamuh
01-19-2005, 06:53 PM
not to be bashing on the xA/xB but i cant believe theres wheel hop with only 108hp! besides stickier tires you could also consider some motor mount inserts. theyre usually only like ~$25, but can be a pain to install sometimes. i have no idea if any are available for the xB yet though. ive used ES mounts in a few imports and it cut down on the wheel hop. you will notice a little vibration at idle, but nothing too bad. theres also the option of an engine dampener. it basically acts as a shock to prevent the motor from rocking too much. i also have no idea if they make these for xBs though.
Epitrochoid
01-19-2005, 07:09 PM
My xA RS has the stock 205/40/17 Yoko Avus and Trac. It wheel hops like mad with the Trac ON. If I take the Trac off it will spin but without hop. Of course then the torque steer comes on.
jct
01-19-2005, 11:46 PM
i only get wheel hop going up hill when its wet outside
pkoule
01-20-2005, 12:04 AM
What he said..
Yeah, i get hop in the rain with trac on, too. Wet conditions make it difficult to get heat into the tires.
The situation is entering a NYC highway (west side highway) from a short merge lane with a stop sign before the merge. Accelleration to 40 needs to happen in a short distance, as traffic is tight.
Good to know i'm not the only one. Guess i'll swap out the tires when these wear out.
fusionscion
01-20-2005, 12:24 AM
its a fwd. theres gonna be wheel hop with the stock tires. if you want no wheel hop, upgrade to stickier tires. if you don't want to spend money, then u might want to change ur driving habits. u say u get wheel hop in low traction conditions....are you trying to get off the line quickly? if you are, try slipping the clutch a little bit. or warming up the tires first. to a certain extent u are right, but i have 18" rims and falken ziex low pro tires and i still get wheel hop, but i adapt to it cuz im in a 5 speed. :bow: hey hey i just noticed we got new smilies..........hey hey lol................p
Xbilly
01-20-2005, 12:44 AM
There is someone to thank for those new smilies, i just don't remember who. everyone gets at least a little wheel hop in some situation, I'm used to it from my CRX. Light weight cars
