MPG
Old Jun 6, 2009 | 03:45 PM
Immolatus's Avatar
Default MPG
I love my car. Its been a pleasure to drive every day, and I've had not a single issue with it that I didn't directly cause on my own. The one thing I can't seem to figure out though is why on Earth the gas milage is so horrible! Has anyone figured out anything we can do to improve gas milage significantly without major modification (weight reduction, significant engine modification, etc)? I love my car, but I'm getting tired of the 23MPG! Any suggestions?
Old Jun 6, 2009 | 03:55 PM
Yanki01's Avatar
then get one of these...
Old Jun 6, 2009 | 04:24 PM
mystik's Avatar
CinSity Scions
if youre doing a lot of city driving, then you cant expect much better than around 23-25 mpgs...otherwise if youre doing a lot of highway driving, stop driving so fast, stop mashing on the gas pedal. 55-60mph is the optimal for gas saving.
Old Jun 6, 2009 | 04:31 PM
puddlestc's Avatar
you get better gas mileage than i do. i get 19-21 from city and highway. Just this past two weeks i tried driving speed limit wherever i went and managed to get 25mpg LOL. never doing that again.
I say get an intake and drive speed limit.
Old Jun 6, 2009 | 05:27 PM
InfideL's Avatar
23 mpg is not the worse. Try overinflating your tires by 2 psi
Old Jun 6, 2009 | 06:02 PM
draxcaliber's Avatar
there really isn't much you can do as cost effective ways of saving gas other than proper vehicle maitenance, and driving habits.
have your tires properly inflated, or overinflated by up to 5 psi over specs, use open windows and sun roof at speeds below 55 mph and then close them up and us a/c when going over 55 mph. don't accelerate aggressively, coast to stops in gear to make the ecu cut fuel to the engine. unload any unnecessary weight from the car that you don't need to take with you everywhere.
but seriously, your mpg isn't that bad. it is roughly what i get.
Old Jun 6, 2009 | 06:24 PM
Hyghgynx's Avatar
Quit giving rides to chubby girls. j/k
I get 26 MPG here in the city and 33-35MPG on the highway. A lot of it depends on your driving style,
road conditions, geography, etc. The MPG shown on the sticker are estimates, not exact figures.
Old Jun 6, 2009 | 06:30 PM
TeeCizzle's Avatar
STOP having a Lead Foot!
I had to retrain my driving style...That was hard!!!
But NOW I've been getting 25MPG city.....29MPG Freeway....
Old Jun 6, 2009 | 10:31 PM
ack154's Avatar
Ease off the gas - like everyone has mentioned. Don't floor it coming away from a stop sign. Drive the speed limit on the highway. These things WILL make a difference if you can do them.
Like someone else mentioned, air pressure is another maybe. AT LEAST make sure the air pressure is correct (check when cold, in the morning). If it is, try adding 1-2 psi to see if it'll help.
Old Jun 7, 2009 | 03:31 AM
yaamakoh's Avatar
I have an aem cold air intake and a trd axleback exhaust, before without the intake i was gettin roughly 320-335ish going all highways on 13 gallons. Now with the cold air intake, driving roughly 80 all the way, I got 380 on 11 1/2 gallons, driving from NYC to Rochester.
My car is dropped low with tein basic coilovers, 2.5 in the front 2.7 in the rear, negative camber, with 4psi more in the rear tires.
I went with I guess the "myths" of saving gas mileage, bought an intake, gets better drag when lowered, higher air pressure in the rear and the results were phenomenal. I mean, it's a huge improvement to what I did have, and if I did drive "normal" I could have probably even pushed it further >:].
Just my 2 cents.
Old Jun 7, 2009 | 03:41 AM
Johnny_Boy's Avatar
same thing everyone else said, you don't have to go super slow, just don't gun it after stoplights. If you're in stop and go traffic, i learned that it doesn't matter how fast you go because you're going to have to come to a stop anyway
i went from about 20mpg city to about 29mpg...and i don't use my a/c unless I'm on the highway
Old Jun 7, 2009 | 07:01 AM
Go4shoped's Avatar
wtf im getting 17mpg.
knew i should have gotten the tacoma v6
Old Jun 7, 2009 | 07:13 AM
InfideL's Avatar
then u would get even less and then what?
should have gotten a hummer??
Old Jun 7, 2009 | 07:39 AM
SFTifoso's Avatar
I get 18 MPG. Mostly city and whatever highway driving I do at 80 MPH. With my driving style that's not too bad. I can't drive without heel and toeing or rev-match downshifting. I never learned how. I taught myself how to drive stick, and all I had to learn was Best Motoring and Option DVDs.
Old Jun 7, 2009 | 06:14 PM
TRDIZZLE's Avatar
check your tire pressures, i also noticed that changing to an 18 in rim lowered my MPG by 2-3 mpg.
Old Jun 7, 2009 | 06:16 PM
Go4shoped's Avatar
actually i drove my grandparents' for a couple of weeks and got the same gas mileage, 17 city. Then again i wouldn't drive a tacoma as agressively as i do the tc.
Old Jun 7, 2009 | 06:19 PM
DJ08tC's Avatar
^^Well maybe that is your problem, I have never gotten below 25 mpg. If you drive crazy don't expect to get good gas mileage and don't complain about it.
Old Jun 7, 2009 | 06:57 PM
AAG's Avatar
AAG
DeepSouth Scions
If you keep it under 3000 RPMs while driving you will see your MPG go up. I tried it for a week and I used about a 1/3 less gas than I usually do.
Old Jun 7, 2009 | 07:34 PM
Andrew1782's Avatar
If your getting 23 don't complain its what the window stickers epa gas rating statez for city driving. To those getting 17-18 all I can say is WTF? How do you drive? lol
Old Jun 7, 2009 | 08:19 PM
sw09's Avatar
walk?
