Zman
http://www.radioshack.com/product/in...ductId=2102780
radioshak seems to have them...quick google search will help
power is at the fuse tap...and ground will be found in all the usual places,,there is a piece of metal behind the little cup thing above the glovebox..pull that out and you can ground onto that metal piece
you have to have a complete circut
put your switch somewhere in that circut...to control power to the circut
it's not rocket science
y6ou do still have my number..if you need to
just give a call
I'd be happy to help
just give a call
you do still have my number..if you need to
just give a call
just give a call
just give a call
just give a call
just give a call
just give a call
just give a call
just give a call
just give a call
just give a call
holy cow..there was a SNAFU on this site this morning..
I clicked to post..and it showed on my computer that a post was never made
6times!!!!
I hope one of the mods can get in here and fix that...
sorry for the multiple multiple posts
6times!!!!
I know I need a circuit, I'm just not sure how to make a circuit if only one wire leaves the fuse box.
BTW, Radio Shack does not have fuse taps, at least the local one.
They have a drawer of "fuse holders", but none looked like that giant pic in the first post.
It was probably out of stock.
The guy was also kind of a D-bag, but that's to be expected.
print out the picture...the link I put up for radio shake was for blade fuses..the mini fuses are pretty much the same
use the wire from the fuse box to bring power to whatever circur yout making..and...ground in the most convienient spot for your applicaation
I just wired up an AC inverter to mine..and mounted it where the ash tray used to be
