Help fuel pump!! (fixed now bigger problem...))))
Old Jun 15, 2009 | 05:30 PM
scion_andrew's Avatar
Default Help fuel pump!! (fixed now bigger problem...))))
my fuel pump wont kick in mt airbag light wires were cutt off would that have anything to do with it?
My car wont start
Old Jun 15, 2009 | 06:15 PM
ack154's Avatar
I'm really confused. I think you need to start from the beginning.
Your car won't start... so you think it is your fuel pump not kicking in? How did you come to that conclusion?
And how did your airbag light wires get cut off?
WTH is going on over there?
Old Jun 15, 2009 | 07:50 PM
Ok well i was installin some new seats an u know how theres the wired to connect the airbags? well my friend cut them off cause he said that they look stupid caus e u would always be able to see them with my old seats.
So befor that my car would start fine and now it wont start at all.
In the manual it states that the fuel pump turns off if in a ccident and i was thinking since they were cut the car thinks it was in a accident. and now even when i spliced the wires back it still wont start
Old Jun 15, 2009 | 08:08 PM
ecko04's Avatar
Have you tried resetting the ECU?
Taking the battery post terminals off for a minimum of 3 minutes and putting them back on.
Old Jun 15, 2009 | 08:09 PM
J-rod17's Avatar
lol, why would you let your friend cut random wires....
Seriously though maybe try using electrical tape and wrap them together....
Old Jun 15, 2009 | 08:11 PM
ya i tried re setting the ecu and i did re wrap the wires.. still nothing idk wat to do. u can tell the car wants 2 start theres just no fuel
Old Jun 15, 2009 | 08:16 PM
scikotictc232's Avatar
What does your friend drive ? you just let your friend CUT wires on YOUR car ? those seats better be worth all this, what are they anyway ? As far as the car not turning on try putting the old seats in reset it and then try to start it. I have never heard of this though.
Old Jun 15, 2009 | 08:18 PM
ecko04's Avatar
Exactly what he said. Put back in the old seats and plug back up the harnesses and hope it works and the airbag doesn't pop out and kill you. Your friend shouldn't be working on a car; cutting plugs off harnesses makes it damn near impossible to return to stock.
Old Jun 15, 2009 | 08:19 PM
i dont even have the stock seats. i went from celica seats to some brides. but my wires were never connected so why would it matter ahhh idk wat 2 do!!!!!!!! its not the fuel pupm cause i replaced it right now an still nothin...
Old Jun 15, 2009 | 09:35 PM
wat else should i try???
Old Jun 15, 2009 | 09:58 PM
kicking your friend in the *****.
Old Jun 15, 2009 | 10:22 PM
ecko04's Avatar
multiple times
Old Jun 15, 2009 | 11:41 PM
BZinn1's Avatar
Dear god.......what is wrong with people.......agreed go kick him in the ***** multiple times......a rule to live by.........never cut wires.......never cut wires used to operate safty equipment in a car.........never let friends cut wires in your car.......go under the hood and pull you r fuses one at a time and find the blown one.......
how do you know your fuel pump is working,can you hear it pumping??????
now go kick your friend again..........any wires under the seats can be tucked under the seat and unseen 100%........goodness not sure why it is so hard for some people......go kick your friend again.
Good luck.
Old Jun 16, 2009 | 12:15 AM
ecko04's Avatar
Seriously though if you turn the car to ignition you should hear the fuel pump pressurize the system. If you don't hear it or can't tell then look under your hood and undo the fuel line, its easy to do, and that will let you know if any fuel is in the system. Tell a buddy to turn the car to ignition on with the fuel line undone and if you don't see any fuel then the fuel pump fuse or relay is bad. I think its a fuse though if i'm not mistaken but I could be.
Old Jun 16, 2009 | 01:03 AM
No fuses are blown. an when i crank it i cant hear my fuel pump.. i did undo the fuel line under the car an nothin happens even if i try 2 start it. notin comes out
Its like the car want to start but fuel just isnt gettin to it..
Wat else weould it be?
i chech every fuse
Which relay would it be if any ?
Old Jun 16, 2009 | 03:21 AM
Murphys_Law's Avatar
find new buddies
Old Jun 16, 2009 | 04:18 AM
BZinn1's Avatar
do you have a voltage tester.......you need to unplug the power from the pump and see if you have power to it,then check to see if you have power to the coils,then check to see if the injectors are opening and closing.......the fuse or relays for any of these things are able to make it not work.
Old Jun 16, 2009 | 04:53 AM
yellowxhoodie's Avatar
you shoudlnt hear your fuel pump when you crank it anyways.
put the key in and turn to the acc. postition, you should hear the fuel pump buzz very briefly.
did you check all the fuses in the kick panel as well? thats where alot them are for fuel. i had a problem once before and it turned out one of the fuses was just loose.
Old Jun 16, 2009 | 03:57 PM
when i put it too acc i dont heear anything i checked every fuse and still nothin..
Well the tow truck is on its way im a failure haha
Old Jun 16, 2009 | 08:15 PM
An heres my car getting towed
