non factory fog light install..
so i got me some LED fog lights...more so driving/marker lights...but they were super cheap and look great! i want to know how you guys go about installing these to the stock fog light plugs behind the bumper...im going to the dealer today after work and ordering the fog light switch cause they didnt come with one...let me know if there is something else i should order while im there...i was wondering if they could hook me with the end pieces (on the stock ones) so that i can plug it nicely into the stock spots...
thanks
thanks
found the switch...from the dealer...its 60!!! going to see if i can find it cheaper anywhere else...can anyone suggest an alternative switch that will work with the stock plug coming from underneath the dashboard...
How hard is it to find the plugs for the foglights??? And I'm hoping you didn't get the LED's that I bought because they didn't last more than like 2 or 3 months.
Mine were 15 bucks from advance auto parts.
I would find an accessory or ignition switched +12v source nearby and use that on one side of the switch, the white wire from the oem fog harness (to oem relay) on the other side and either use the fog harness ground wire (blue?) or run your own. There is an existing ground point behind the DS kick panel that would work well. It takes very little current to close the relay so you shouldn't have to worry about overloading the +12v switched circuit you use.
I plan to rewire mine as desrcribed above, asap.
Those might look good mounted in the side bumper vents...
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
umnitza
Dec 1, 2014 06:26 PM
