need some help with the xb first gen engine
Old Jun 20, 2009 | 04:21 AM
davidward's Avatar
Default need some help with the xb first gen engine
i just installed a turbo kit on my xb and is having engine problems. I think i spun a rod bearing.. i was wondering how do you take the time chain off.. never had to deal with a timing chain before..
Old Jun 20, 2009 | 08:04 AM
Crispyxb's Avatar
I have an extra xB motor in my garage, I will look at it tomorrow and see how to get the chain off.
Old Jun 21, 2009 | 01:39 AM
davidward's Avatar
OK i looked into it a little bit more..... Its not a bent valve or anything to do with the valves i think.. I took the small oil pan off and there is small chunks of aluminum in the oil. i think they are parts from a rod bearing. I need some help thou i cant get the crank case/ upper oil pan off to see the connecting rods. I removed all bolts. I was wondering if there is a couple bolts holding it on on the transmission side. Mine is an auto. Can you remove the lower crank case/ oil pan without removing the transmission?? I havent messed with the timing chain yet
Old Jun 21, 2009 | 09:32 PM
Crispyxb's Avatar
I have a motor in my garage like I said. I didnt get a chance to look at it. I got pretty busy. But the only thing wrong with it is the rings. So if you need anything off it let call Ambers phone and see what we can do.
Old Jun 21, 2009 | 10:15 PM
davidward's Avatar
Thanks bud.... Ummm so yeah i dropped the lower crank. Nothing is wrong with the rods and bearings. So the only thing left that can be making the noise is the valves.. It must be a bent valve or a stuck valve... im going to buy forged pisons and rods. might as well build the lower end to run 15 psi
Old Jun 21, 2009 | 10:26 PM
hawaiianxbzee's Avatar
are you running any engine management??
Old Jun 21, 2009 | 10:30 PM
davidward's Avatar
yeah....... just didnt get it tuned right away.. I messed it up.. I think it pre fired. cause what every happend..
Old Jun 22, 2009 | 12:24 AM
thats probly pieces of your pistons in there. that motor is done.
Old Jun 22, 2009 | 01:11 AM
davidward's Avatar
well i found the problem.. I found the aluminum pieces went... after removing the head and pistons.. number one rod was bent and twisted. thats what caused the noise. the bottom of the piston was hitting the crankshaft counter weight...
Old Jun 22, 2009 | 06:01 PM
Just1n's Avatar
Wagonistas
That blows. Sorry to hear that
Old Jun 22, 2009 | 07:54 PM
NoLimitzBuilt's Avatar
Team No Limitz
How much boost where you running?
Old Jun 22, 2009 | 09:05 PM
davidward's Avatar
9 psi.......
Old Jun 22, 2009 | 10:54 PM
arizonaturbo's Avatar
Originally Posted by davidward
9 psi.......
All I can say is "BOOM". 9 psi without engine management> I am with ***** on this one; I think the piston rings and/or piston is cracked.
Old Jun 23, 2009 | 03:57 AM
detination. happens when you dont know what youre doing
Old Jun 23, 2009 | 06:00 AM
Crispyxb's Avatar
Time to pick up a used $350 motor and replace it like I had too.
Old Jun 23, 2009 | 07:04 AM
davidward's Avatar
engine is good and i was using an engine manangement. it just wasnt tuned... everything is good just need new piston and rod.. cyclinder walls mic check good. i order 75mm bore 8.5 compression ratio wisceco pistons and forged 1" thick piston rods. so i will be able to run 20 psi. im sending off my cams to get done with valves and springs. i know my tranny will not hold up to the power..
Old Jun 24, 2009 | 03:28 AM
i would love too see a xb motor on 20 pounds of boost. whos gonna build it?
12thhawksfan
Jul 14, 2015 06:18 AM
jchuma
Feb 11, 2015 12:55 AM
Halo19boy
Jan 27, 2015 10:19 PM
NonStopTuning
Jan 20, 2015 05:20 AM
Ramroids55
Jan 16, 2015 02:42 PM
