dollar5
01-21-2005, 07:25 PM
i was talkin to a local scion life member about his xb and he recomended me to do up the ground kit and remove the intake restrictor.... its not that i dont trust him it just seems like these arent completed by the factory for a reason.
frist off the ground wire kit in the tech section.. .http://www.scionlife.com/forums/viewtopic.php?t=29261 ..... its probally obvious that i dont know much bout cars but how does this improve anything? are you guys sure its not the placeebo effect? i know you all know alot more bout cars then me but im just curious if anyone can help me understand its effect on my box... also does it have any negative effects on the car, either gas mileage or other long term negative effects.
secondly the air intake restrictor, is it worth removing? it must be there for a purpose right? or is it just out crappy american goverment ruining more fun aspects of our life. but it seems the the xb has little power so why restrict it further with an intake restrictor, and the same goes for this mod, if i remove it will it have any negative effects on my ride?
and since im at it, is it possible to abuse overdrive? i find my self on the highway quite often as most people in jersey are so i usually keep overdrive on, and even when i hit back roads i usually keep it on, is this bad? should i never use it? or use it for highway only? i like it cause it keeps the rpm's down but at what cost?
sorry for the hat trick of lame questions but i hope someone can enlighten me...
thanks guys.
thanks guys.
