spacers question
Old Jun 25, 2009 | 06:34 AM
cdeeznutz's Avatar
Default spacers question
i'm on 18x7.5 +47 offset ce28's and dropped on htechs. what size spacers should i get for a more flush look without rubbing issues?
Old Jun 25, 2009 | 06:43 AM
Air2TheThrown's Avatar
what size/spec tires do you have?
Old Jun 25, 2009 | 03:02 PM
HKSpeed's Avatar
15mm.
i had 18x7.5 et33 LE28Ns (which is a CE28N with a polished lip). i also had a 5mm spacer in the rear. no rubbing at all. i was on 225/40 Toyo Proxes 4s. i was running 1 finger gap in front, 1.5 finger gap in back on tein coilovers.
Old Jun 25, 2009 | 03:41 PM
cdeeznutz's Avatar
tires are falken ziex 912 225/40/18
Old Jun 25, 2009 | 03:50 PM
cdeeznutz's Avatar
HK: looks very clean.
anyone know if spacers affect tire wear, alignment, or gas mileage? i just want to do it right. thanks.
Old Jun 25, 2009 | 04:18 PM
o8tC's Avatar
why would it affect gas mileage?
Old Jun 25, 2009 | 04:29 PM
cdeeznutz's Avatar
^i don't know, sounds stupid but i heard some rumor that it does.
Old Jun 25, 2009 | 04:38 PM
gp1817's Avatar
what kind of spacer do you gies recommend using on the stock tires.....or so i say stock rims..wanna make it look nicer
Old Jun 25, 2009 | 06:04 PM
davedavetC's Avatar
H&R 20mm front and rear
Old Jun 25, 2009 | 08:07 PM
gp1817's Avatar
they go right on.....do i need anything special
Old Jun 25, 2009 | 08:17 PM
davedavetC's Avatar
they come with new studs that youd have to replace the factory studs with them
Old Jun 25, 2009 | 10:08 PM
o8tC's Avatar
yea it doesn't make sense at all.
Old Jun 25, 2009 | 11:16 PM
cdeeznutz's Avatar
would i have to get new lug nuts? I've got a set of Rays shorts right now...
Old Jun 25, 2009 | 11:31 PM
--Final_Wrath--'s Avatar
Ichiba spacers are the best way to go...you can prolly get a set off ebay. Im running 25mm in the front and rear. 18x.7.5 with 42 offset....very flush with the fender, but you WILL rub...even after rolling the fender, the back piece still touches sightly. And im runnin Falken 912s also...looks nice, but go with the 20mm spacers save ur self some trouble.
Old Jun 25, 2009 | 11:36 PM
http://www.fastscions.com/toyotascio...versionii.aspx
Those are the ones you would want...you wont need new studs or lugs
Old Jun 26, 2009 | 12:31 AM
davedavetC's Avatar
those are tricky tho because you have to make sure that y ou have clearance on the wheels for the bolts.
my old volks didnt have the clearance so i couldnt run those.
your best bet would be to get the H&R spacers and replace the studs, you can still use your exsisting lugs no problem
Old Jul 1, 2009 | 06:46 PM
superwhite08's Avatar
i vote for 15mm spacers - 20's are huge and dont look so nice thru your rims..
Old Jul 1, 2009 | 06:48 PM
rays lugs are fine - everyone i know who has spacers has H&R and they just got them with the stud extensions so they were fine.
Old Jul 1, 2009 | 09:03 PM
davedavetC's Avatar
what?
the lugs dont matter when it comes to the spacers, you need extended STUDS not lugs lol
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
