View Full Version : air breather
09crimsontc
06-27-2009, 07:55 AM
what exactly do they do and where do they go? anyone got a pic of theres on a scion
tCtCtC
07-05-2009, 01:42 AM
Assuming your talking about the one on the valve cover, it usually connects back into the intake. But when you have a breather you attach a small filter to it.
chicotunner07
07-05-2009, 02:04 AM
does nothing for performance, but supposedly it keeps your throttle body and intake manifold from becoming black and sooty from oil vapor coming thru the pcv hose
here some pics
http://i153.photobucket.com/albums/s222/chicotunner07/DSC_0021.jpg
http://i153.photobucket.com/albums/s222/chicotunner07/DSC_0026.jpg
http://i153.photobucket.com/albums/s222/chicotunner07/DSC_0022.jpg
DeiselFuel2o2
07-05-2009, 11:10 PM
Does it throw any CEL's? Does it affect MPG at all?
Just wondering
tCtCtC
07-05-2009, 11:16 PM
No and no.
09crimsontc
07-05-2009, 11:54 PM
looks nice i wanna get one where can i order or pick one up?
DeiselFuel2o2
07-06-2009, 03:16 AM
I've seen them at autozone or advanced auto parts.
their like 15bucks though....only 3 bucks more than a new PCV valve, I would totally get one if I wasn't on a life budget right now...
chicotunner07
07-06-2009, 04:47 AM
yep, autozone, then you cut the stock hose, and you will have to trim the tip of the rubber entry on the breather itself to fit into the hose end
so it will be
valve cover >2 inch of oem hose <breather
hope you understand
scuds03
07-06-2009, 09:11 AM
You should read up on how the PCV system actually works.
Your ideas don't make much sense. The breather tube allows air INTO the valve cover, not the other way. It is called a POSITIVE crankcase ventilation. Air is pulled into the valve cover and the air travels though the head down though the bottom end and pulls the oil/exhaust/fuel vapours out of the block (because piston rings dont ever make a perfect seal) and through the PCV valve and gets burned. By replacing the hose with a filter, the block is no longer pressurised by the intake and you are preventing the PCV from venting those vapours inside the motor and this will cause your oil to get contaminated much quicker and you will see increased engine wear. This mod will shorten the life of your motor.
In other words, if you don't understand how it works, leave it alone.
chicotunner07
07-06-2009, 01:29 PM
^just researched a little, and hes right, lol, i dont think you would see any real damage right away, but you never know, so thank you stranger for bringing that up, dont mind being told when things are bad or could be made better, so ill be replacing the hose soon, lol
so no breathers people
09crimsontc
07-06-2009, 08:57 PM
thanks bro^^^
chicotunner07
07-06-2009, 10:42 PM
i did it cuz i had one laying around, but if you're trying to spruce up your engine bay a little, they sell colored silicone hoses in autoparts stores too!
scuds03
07-06-2009, 10:59 PM
I didnt mean to sound like an _______ earlier I just dont want you guys wreckin your motors! :)
I know most people do the filter because it does look neater than having a hose but its just bad for your motor. But if you think it adds that extra little ooh and ahh for a show pop it on when the cars at the show then take it off after. Just dont drive around like that.
crush02342002
07-06-2009, 11:24 PM
i did mine that way when i was boosted and didnt have a nipple to route the hose into the intake pipe...eventually i got a different intake pipe and put a catch can on it...
stock it is routed into the intake which would pull a vacuum on the head.
AdmirN
07-06-2009, 11:39 PM
Would it have any affect on the engine if you were to have a oil catch can?
crush02342002
07-06-2009, 11:51 PM
nope...you would benifit from it as oil vapors are being collected instead of going into your intake and mixed with fuel.
chicotunner07
07-06-2009, 11:53 PM
^yeah, and you would still have the vacuum effect, and also the bling, lol
best of both worlds!
crush02342002
07-07-2009, 12:00 AM
just before turbo install (best pic i have of the filter)
http://i264.photobucket.com/albums/ii164/crush02342002/IMG_0432.jpg
install day
http://i264.photobucket.com/albums/ii164/crush02342002/IMG_0507.jpg
then catch can
http://i264.photobucket.com/albums/ii164/crush02342002/oilcatchcan4.jpg
intake side
http://i264.photobucket.com/albums/ii164/crush02342002/oilcatchcan5.jpg
valve cover side
http://i264.photobucket.com/albums/ii164/crush02342002/oilcatchcan7.jpg
scuds03
07-07-2009, 01:18 AM
You only really need a catch can if you are running boost. But if your NA and want one to have another pretty hing under the hood it wont hurt anything like the filter will.
rosedaleny806
07-07-2009, 01:22 AM
so no CEL's nothing? wat about on the intake the nipple thing where the old hose use to connect to the intake? do u jus leave it open or what? or do u jus plug it?
chicotunner07
07-07-2009, 01:58 AM
with the breather, i plugged it
and no check engine light unless that hole isnt plugged
crush02342002
07-07-2009, 02:23 AM
pluged it...if not air leaks past the maf and yeah the car doesnt like that one bit...lol
crush02342002
07-07-2009, 02:24 AM
btw an oil catch can isnt just for those that are boosted
scuds03
07-07-2009, 09:15 AM
Nobody on this forum except mabe 1 or 2 people are going to have an NA built TC serious enough for a catch can to do anything for them.
