View Full Version : JDM body kit fitment issues
Scion4life
01-22-2005, 04:06 AM
I am getting ready to order the spirits advangaurd kit from Japan and an a little concerned with fitment issues.I am more than capable of doing modification(i.e sectioning,gap fitment ect.) But for $1600 i would hope it to be minimal.I have heard that JDM BB's are about 2 inches narrower?I have also heard that the bumper supports are smaller,thus needing to trim or get rid of all together the U.S. support.A knowledgable reply from somone with a true JDM kit like the Fabulos or the Spirits would be greatly appriciated.
bBlover
01-22-2005, 05:04 AM
It should be fine. As long as it is not for the xB with the license plate frame in the bumper.
Orataro
01-22-2005, 05:13 AM
I've also heard of stories that the bB is narrower then the xB but I've found this is not true. I've ordered many JDM body parts for my xB and have not had any problems at all other then the headlights. Keep in mind that aftermarket parts such as body kits made of fiberglass tend to shrink a little but 2", I think not. Yes, there maybe some changes in a USDM model from a JDM model but that's normal. But, as for the bB being narrowier the the xB, I find it false.
Good Luck!
squirrel
01-22-2005, 07:12 AM
AS long as the body kit you order is for a Version 2 bB, you'll be fine. In regards to a body kit being short 2 inches, try more like an inch. Why? Because its a Version 1 bB body kit being fitted to a Version 2. Version 1 has the short bumpers.
Scion4life
01-23-2005, 12:53 AM
thanx for the replys,but would still like input from someone who has the spirits kit currently that could give me some input?anyone know someone?
squirrel
01-23-2005, 01:44 AM
PM John (ScionJOhn) Nor*Cal's food tester. He has the Spirits kit.
Opr8r
01-23-2005, 09:34 AM
Brad is right. Let me also say that kits from either generation will fit. However, 1st gen bB kits require that the USDM 5mph bumper reinforcement bars (both front an rear) be removed.
BTW... the Noblesse kit is on!
Re: Spirits Kit
Make sure you have your suspension dialed. Since the Spirits kit is a VIP kit, it was made with air suspension in mind so naturally, it extends significantly lower than stock. That's also why it's touching the ground when parked in most pics. You are guarenteed to scrape if you are running the typical 2" lowering springs.
Peace,
m@
Scion4life
01-23-2005, 04:23 PM
I have the tien basic set-up with 19" and all the way down i still have 3-4 inches of clearence.I think I could raise it up for around town,lower it for shows.Any more info would help.
OPr8or
I sent you an email about the NU Jack ALLUre.do you still have pics,and info on where to get that kit?
