sciontcmm
06-30-2009, 10:23 PM
Do tCs have a rubber plug that could be removed so you can access it to remove dings and dents on the rear quarter panel?
View Full Version : Door Jambs sciontcmm 06-30-2009, 10:23 PM Do tCs have a rubber plug that could be removed so you can access it to remove dings and dents on the rear quarter panel? SquallLHeart 06-30-2009, 10:35 PM no.. but you can remove the entire interior panel. sciontcmm 06-30-2009, 10:39 PM In the back seat, the panel there you mean? or the door panel? How hard is it to remove? The door panel won't help me. There is def not a factory hole that was silicone plugged to access? DJ08tC 06-30-2009, 10:58 PM Just take off the rear panel next to the back seats and it will give you full access to the 1/4 panel. Here is a tech on how to take apart the interior http://www.scionlife.com/forums/viewtopic.php?t=60981 BZinn1 07-01-2009, 12:01 AM you should be able to gut the interior in under 90 minutes even if yo never did it with the directions listed above. |
