View Full Version : Auto XB AEM intake rattle
Cameron
01-26-2004, 03:21 PM
After installing my AEM intake, I've noticed a rattle at stop lights. I've deduced this will be only evident on Automatics with the AEM intake.
The AEM attaches to the transmission with one bolt. In Drive gear, at full brake, the transmission vibrates at a different rate than the engine. If clearances are not just perfect with the AEM intake, a faint rattle may sound as the intake shakes at a different frequency than the engine.
I've made a few adjustments, now the rattle is only very very faint (I'm the only one who notices). Has anyone else experienced this? Is there a sure-fire solution?
izzles
01-26-2004, 03:39 PM
I have found thats its where the sensor is at near the valve cover I have cut that extra part on the intake to where that sensor sits and let it hang you will find that it doesnt vibrate reallt much after that.....
Cameron
01-26-2004, 09:44 PM
I'll try it, but I don't think that's it. I already got the VCV electrically taped to the intake extension where the VCV is supposed to "clip" on.
Thank you tho.
showpaojoe
01-26-2004, 10:02 PM
same problem on my manual. when i slow down or stop. goin 2 months strong now
Djuan
01-26-2004, 10:34 PM
I'm glad you guys mentioned that I was thinking of getting an AEM intake... Do all the intakes rattle ?
proto_k7
01-26-2004, 11:37 PM
My blitz rattles at the valve cover- :x
scionaraxb
01-26-2004, 11:44 PM
No rattles here..AEM w/ auto.
Cameron
02-02-2004, 03:21 PM
Rattle source found.
The AEM filter element was vibrating against the back of the FOG LIGHTS. I just shifted the filter around and the rattle stopped.
I may anchor the filter away from this area using zip ties or silence it with a thin strip of foam rubber and some tape.
The connection of the filter to the intake pipe is rubber, so I may even be able to angle the filter away from the back of the light.
Scionaraxb, do you have fog lights on your car? Just wondering.
George
02-02-2004, 03:38 PM
This is a common problem with the AEM intake.
Also, check under the intake pipe to make sure that it isn't contacting the air bag sensor on the "frame rail". I saw one that had almost worn a hole through the intake!
George
EcksBee
02-02-2004, 04:07 PM
your first problem is that you bought the AEM intake..sell that back to toyota and get an Injen.. It is bad ___....
squirrel
02-02-2004, 04:27 PM
my Injen intake doesn't seem to make any rattling noises.
Cameron
02-02-2004, 04:43 PM
Just trying to help those with an AEM intake that does rattle, thanx :)
Djuan
02-02-2004, 06:46 PM
rattle source found
http://www.hmsdc.com/images/maracas.jpg
