HELP: With my Third Brake Light....
Old Jul 5, 2009 | 05:20 PM
toyotaguy's Avatar
Default HELP: With my Third Brake Light....
Hey guys,
My stock third brake light isn't lighting up completely. When I step on the brake the third brake light lights up, but hardly noticeable.
Could this be a loose plug or are my led's burnt??
Thanks for any help,
Old Jul 5, 2009 | 05:53 PM
cjr5137tc's Avatar
what u mean not completely it only lights up in the center about 4 inches. the whole thing does not light up unless u mod it.
Old Jul 5, 2009 | 06:01 PM
toyotaguy's Avatar
^Sorry should have been more clear.
It's a stock tbl, so only the middle is suppose to light up. The problem is when I step on the brake the tbl hardly lights up. You can't see the tbl light up unless its completely dark outside and you stand a couple feet in front the the tbl.
Could this be a loose plug somewhere or is it time to replace it?
The last thing I had installed is my Viper 5900 with 2 529t's.
Old Jul 6, 2009 | 12:48 AM
tcCALI's Avatar
^ good reason to get a new tbl from LED-HEADZ or OZNIUM.....
Old Jul 6, 2009 | 01:23 AM
toyotaguy's Avatar
^ Yeah it is, but I don't really want to buy a new one if I don't have to.
Anyone have a suggestion on how to fix this?
Old Jul 6, 2009 | 01:38 AM
BZinn1's Avatar
open up the hatch and take a look........there area two screws on the hatch cover inside,remove the trim around window inside and give it a yank by the handles and it will come right off,takes like 4 minutes,look for loose plug,if nothing works you need new light.......
Old Jul 6, 2009 | 02:40 AM
tcCALI's Avatar
if ur under warranty take it in....
Old Dec 28, 2009 | 02:56 AM
cntntntstsfd's Avatar
toyotaguy, did you ever determine what caused your tbl problem? mine is doing the same thing now. really dimly light when brakes applied.
Old Dec 28, 2009 | 09:33 PM
808tC's Avatar
mines has gone out so my 3rd brake light doesnt work anymore.
im betting its either a burnt out bulb or a burnt out fuse.
Old Dec 30, 2009 | 01:05 PM
the tbl is a set of several led's so they wouldn't burn out across the entire brake light. i checked my fuses and they are good. it has to be something in the circuit board they led's are attached to but i was really hoping to not have to replace the whole thing.
Old Dec 30, 2009 | 01:31 PM
bksleepaaay81's Avatar
i would use a test light to check each spot on the circuit board to see where you are losing power.
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
