Not sure if this has been ask before. Wondering what this engine could achieve horsepower wise without turbo or supercharger. And just for the sake of arguement lets take the money out of the equation. And what would you do to get this horsepower? Please be serious in your answers no BS please.
youngflyer
07-05-2009, 09:55 PM
considering rado and kenny tran have both made 700+ HP, i would guess somewhere around there!
Triple6
07-05-2009, 10:02 PM
Is that with or without turbo or supercharger?
youngflyer
07-05-2009, 10:07 PM
oh lord i didnt see that part well to answer your question, money not involved leslie durst made 300hp all motor but she may have been bored to 2.7?!?!
Ace83
07-05-2009, 10:09 PM
those are turbo.. huge ones with heavy engine build.. no turbo or superchareger, no tc has no potential for good gains.. if you spend about same cost as your car without turbo/s/c may be you will reach 300hp.. assuming you got good guys to work your cars..
CSOCSO
07-05-2009, 10:10 PM
:D
without turbo or s/c you can reach 200hp....
but you have to spend 2-3000 dollars on ____ load of stuff
i would go turbo instead.
Iowa_TC1
07-06-2009, 10:27 PM
You should try nitrous, when set up correctly it is very safe and effective.
chicotunner07
07-06-2009, 10:38 PM
well some consider nitrous as another form of forced induction, if money was out of the equation, throw in High comp pistons, shave and balance the crankshaft, light weight rods, and light weight pulleys, then for the head, aggressive cams, valves springs retainers, port and polish, custom individual throttle bodies, injectors, headers exhaust, and most definitely a standalone with a very good tune and a raised redline!
wow that was a mouth full!
im not gonna break down the total cost, but your looking at close to 15k not including labor and all other costs involved!
or you could spend 6k on a turbo kit, piggy back, and still have more HP, lol
Triple6
07-07-2009, 12:01 AM
Thanks Chico, that was the answer I was looking for.
chicotunner07
07-07-2009, 12:05 AM
remember, if you want NA power! Build it like a honda, lol
RSracer
07-09-2009, 11:21 PM
RLZengineering.com did all her head work. so if you wanted a head to flow for high NA #'s I'd start there. They don't do scion engine just head work for import teams.
CarbonXe
07-10-2009, 03:07 PM
And if you're building it like a Honda, you should've got a V8. :D
youngflyer
07-10-2009, 05:39 PM
either way, be ready to drop a lot of money to be hard headed and still slow!
Triple6
07-13-2009, 12:40 AM
Not hard headed (well maybe alittle), and not against Turbo or SuperCharger, just wondering what the motor alone could be built to.
wlfpck
07-14-2009, 01:27 PM
you should be able to at least clear the 240 whp range.
An h22 built will put down about that much power. I don't see why the tC couldn't. It'd be expensive...Really expensive.
chicotunner07
07-14-2009, 02:21 PM
like i said, in order to get it to 240, you would have to go against everything the 2az was made to do, rev fast, rev high, high compression, aggressive cams (since we dont have the luxury of having different cam profiles like vtec) so now your looking at something that might not even be streetable due to crappy idleing and such..
i would love to see this done one day, but it sure as hell wont be me! lol
wlfpck
07-14-2009, 02:44 PM
idk. The compression ratio on the H22 is what really sets it apart. It's at almost 12:1.
I know the 2AZ-FE engine is a low compression which is why people are slapping turbos on them.
The whole point was that there is NO limit to the money spent.
Personally I think it's possible.
stroke it to 2.7 L, Cams, I/H/E, much higher compression ratio. i think that should hit in the 240 range. 200-220 for sure.
chicotunner07
07-14-2009, 02:53 PM
your right, were not saying its not possible, but i have yet to meet someone with "no limit" on money that has an interest in scions, lol
rangerryda
07-14-2009, 02:59 PM
N/A serious power attempts are the biggest waste of time and money for any TC owner. End of discussion. The rods handle about 350 whp and they tend to go first. It doesn't matter how you get there, that is your limit until you want to drop a couple G's building a block.
Tc4Eva
07-14-2009, 03:01 PM
The H series engines arent that high of a compression. The JDM H22A is at about 11:1, while the USDM H22A1 is at about 10:1 Comp. Most of the Honda guys throw in around 12-14:1 comp pistons for their NA builds.
wlfpck
07-14-2009, 03:22 PM
lol well yeah. I'm just going by the contraints of the OP. :P
When I had my cb7 (91 accord) my h22 was running 12:1. But either way 11:1 is a lot higher than the 2AZ-FE. :D
i need to stop sitting on SL at work.
Triple6
07-14-2009, 07:37 PM
Thanks everyone. Now this thread is getting somewhere, I like to see a good, honest discussion on this subject. Keep it coming. :pray:
