ABS and TPMS light problem
Old Jul 7, 2009 | 11:26 PM
jhole's Avatar
Default ABS and TPMS light problem
i took my stock struts off and got tokico struts put on my 05 scion tc. When i turned on my car the ABS and TPMS lights were on. The ABS light stays on constant and the TPMS light blinks.
Old Jul 8, 2009 | 12:07 AM
06scionbhs's Avatar
you didnt pinch any of the lines did you..? like the brake lines? or maybe the mph sensor?... as far as just putting on new shocks goes..you shouldnt be getting any of those problems. Unless you did something wrong did you just put the struts in? howd you go about doing it? you didnt remove the whole brake system did you?
Old Jul 8, 2009 | 01:58 AM
BZinn1's Avatar
hoping you did not leave the assy hanging in the air during the install,if so it is possible to break the sensor to the brakes or pinch a line in a weird way,but it is hard to do........what else did you do other than install struts.
Old Jul 12, 2009 | 12:57 AM
jhole's Avatar
I didnt take anything but the struts off and if anything was hanging it was just for a second to grab the new strut.... i did them all one by one and everything went smooth.. didnt fall into any snafoosl... thought everything was done and great until i turned the car on...
Old Jul 23, 2009 | 12:29 AM
tC_Crisis's Avatar
Make sure Tire is inflated to specs, reach into the glove box and hold the reset button. the light will blink 3 times and go off, the TPMS will be activated for relearn procedure for 10 mins of light driving. This will take care of your tire light assuming your sensors are working properly and you have the right tire pressures.
as for the ABS light, try having a shop scan the Code, that will give you a starting point.
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
toyotaisme
Jan 10, 2015 10:24 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
umnitza
Dec 1, 2014 06:26 PM
bruceb25
Nov 23, 2014 04:52 AM
