No radio reception! HELP ME!
Old Jul 9, 2009 | 06:29 PM
agentapple's Avatar
Default No radio reception! HELP ME!
I have a stock 07 radio with an S2K antenna, my radio has gone out before for about a day or so but this time its been out for almost 2 weeks. I have my stations all programmed but I hear nothing, my ipod works fine tho. So would anyone know what the problem is?
Old Jul 9, 2009 | 06:57 PM
sciontc_mich's Avatar
hmmm.. try turning the radio on and wigging the S2K antenna.. wondering if the connection isn't mating properly.
can you replace the S2K with your old stock antenna and see if that works?
Old Jul 9, 2009 | 07:17 PM
agentapple's Avatar
I lost it :T I tried turning it off for awhile and also removing and re-installing the antenna but no luck
Old Jul 9, 2009 | 09:57 PM
Hyghgynx's Avatar
Stick with the iPod. No commercials and you get to listen to what you want.
I can't remember the last time I listened to the radio.
Old Jul 9, 2009 | 09:59 PM
agentapple's Avatar
I know...but its good to have it once in awhile.
Old Jul 9, 2009 | 10:36 PM
llblutigerll's Avatar
have u checked the antenna plug on the back of the radio?
Old Jul 9, 2009 | 10:42 PM
agentapple's Avatar
Nope, what is that? How do I get to it?
Old Jul 10, 2009 | 12:46 AM
https://www.scionlife.com/forums/vie...ghlight=taking
same step as the tc, sorry couldnt find one for the tc
Old Jul 10, 2009 | 04:49 AM
agentapple's Avatar
Thanks for the help, i'll give it a try.
Old Aug 4, 2009 | 10:25 PM
agentapple's Avatar
My radio isn't working still, any other suggestions?
Old Aug 6, 2009 | 04:53 AM
Chrisb319's Avatar
having the radio in your car is very important incase of storm emergencies, I know living here there have been a few times where we needed it. One thing you could try is to buy another radio antenna (radioshack, walmart(scosh makes one)) and hook it in if your radio does not work at that point then you know it's the deck, because I doubt it's the s2k antenna.
I would also try unplugging your battery. I could not find a reset button on my stock 07 deck so maybe disconnecting the battery or deck will reset it.
Do you hear noise when your in radio or silence?
bump to get the problem solved.
Old Aug 6, 2009 | 04:59 AM
agentapple's Avatar
When on radio mode its silent, nothing comes from the stations, but when I switch to my iPod it works fine. I'll give d/c battery a try when I get a chance, its been almost a month with out my radio lol.
Old Aug 6, 2009 | 07:28 PM
i'm wondering if power is getting to the amplified antenna (stock, yes we have an amplified antenna). If you can, check the power going to the antenna, it might be no power = no signal. Just a thought to try
Old Aug 6, 2009 | 07:38 PM
agentapple's Avatar
Cool, where can I check that? Would a fuse be an issue by any chance?
Old Aug 6, 2009 | 08:22 PM
SquallLHeart's Avatar
the power to the antenna comes from the radio.. so if it was a fuse... then the radio wouldn't turn on..
so.. i don't think it's a fuse.
Old Aug 6, 2009 | 11:06 PM
08_Scion_tC's Avatar
Sounds like one of your connections might be loose inside the headunit itself. Only way to fix that is to replace the headunit.
Old Aug 7, 2009 | 01:05 AM
Jaiyla's Avatar
When the dealership forgot to plug the antenna in on the back of my radio, that's what happened to me: static.
Old Aug 9, 2009 | 01:47 AM
cweckel2000's Avatar
I've swapped radios in my tC twice and the antenna connector is a very tight fit into the head unit. I'd doubt it would just fall out by itself unless you were working in there. I'd say your best bet is get the radio out and take a look...but it very well could be an internal problem in the head unit. Aftermarket units have a lot better sound quality and generally more features. It must just be time to upgrade.
Old Aug 9, 2009 | 05:20 PM
agentapple's Avatar
^ Thats what I was thinking. :]
Old Aug 9, 2009 | 05:27 PM
getaforknjob's Avatar
I would think it has to be something with the head unit itself only because even without an antenna you will still receive some signals.
Double check that antenna plug-in on your deck.
If that's not it, then take it to the dealership.
That's if you are still covered under warranty.
