Engine Reving by itself !!!
Old Jan 24, 2005 | 04:24 AM
MyBoX's Avatar
Default Engine Reving by itself !!!
Hello Everyone, Just wondering if anyone else here has this problem, while my car at stop sign it revs by itself between 650 and 1000 RPM, keeps going up and down, I have ground wire kit for about 8 months but it was fine before, and its been doing this recently, so what do you guys think, thanks for your helps Sean
Old Jan 24, 2005 | 04:52 AM
hotbox05's Avatar
hmm , mine does it all the time too , supposedly it can be adjusted. theres a tsb for it i believe
Old Jan 24, 2005 | 06:09 AM
MyBoX's Avatar
Hey, where can I find that, Thanks dude
Old Jan 24, 2005 | 07:00 AM
jct's Avatar
jct
turn your heater fan off and it goes away ;)
Old Jan 24, 2005 | 07:02 AM
hotbox05's Avatar
not for me , damnit sean do a search for "idle"
Old Jan 25, 2005 | 04:13 AM
flowmini98's Avatar
mine does the same thing....also does anyones seem to rev higher when the blue coolant light is on..?i just noticed it last night..but i wasnt sure ..
Old Jan 25, 2005 | 08:05 AM
hotbox05's Avatar
alot of cars have a high idle upon startup to warm the engine , that and certain things that control the engine via vaccumm are controlled by means of heat.
Old Feb 2, 2005 | 05:22 PM
-Keith-'s Avatar
If its reving up and down ussualy means vacum leak... check your hoses if you have a intake check the hose that connects to it first...
Old Feb 2, 2005 | 05:50 PM
hotbox05's Avatar
yeah thats the normal car fix but alot of these cars come with these problems .
Old Feb 2, 2005 | 06:17 PM
TheScionicMan's Avatar
If it's an automatic, it locks out O/D until it is warm. perhaps that is what you're feeling?
Old Feb 3, 2005 | 05:39 AM
rolex87's Avatar
does it rev fast or slow? if it revs fast, fill up your blinker fluid. If it revs slow, add more nitrous to your tires. If neither of those work, call Scion and tell them what you did. they'll fix it for you. Guaranteed!
Old Feb 3, 2005 | 06:18 AM
squirrel's Avatar
My xB idles between 375-450 when its warmed up. At least that's what the digi tach says. It sounds way too low to me. But its tapped off of the ECU.
Old Feb 3, 2005 | 06:37 AM
hotbox05's Avatar
maybe your needles are off brad. it should be around the 600 area
Old Feb 3, 2005 | 07:09 AM
squirrel's Avatar
That's what the digital tach displays. I know its gotta be off.
Old Feb 7, 2005 | 06:38 PM
Kim_Griego's Avatar
I have had my xB in several times for this. Basically they agree it is not suppossed to do this but they say there is no fix and they say that the engineers will not find a fix unless they get alot of complaints. So everyone needs to complain because all the standard trans xA & xB's do this. Do not let them tell you it is a normal condition because it is not. I have been an ASE certified mechanic for 14 years and I know this is not normal. Remember that they will not fix it unless there are alot of complaints.
Old Jan 20, 2007 | 09:46 AM
Tsuihousha's Avatar
i just saw this thread and wanted to say my car does it also. It doesnt fluctuate really rapidly but it does it sometimes.
Old Jan 20, 2007 | 02:16 PM
Simmo's Avatar
Here's the deal guys. When cold, all cars rev higher.
Now scion's problem is it revs up and down.. Obviously when cold, it revs over 1000rpm and fluctuates between 800-1200. When warm, it fluctuates from 500-850 (for me). SUPPOSEDLY dealer told me that it fluctuates like that because of the aftermarket intake. I think its the biggest bull____, since i've had 8 cars so far with aftermarket intakes and never had rpm jump around. I think their iddle controller is f*ed up, but hey the dealer guys are always right.. NOT.
Old Jan 21, 2007 | 12:13 AM
Tsuihousha's Avatar
I'm going to try to clean my MAF with some of that special cleaner and see if that helps. It could just be the sensor itself is dirty because its sitting right in the intake tube with a more open element filter then oem. So we'l see how that goes.
Old Jan 21, 2007 | 12:23 AM
streetlethalxb's Avatar
Mine has 327 miles on it, and at about 200 i noticed the fluctuation. Its been puzzling me, I am a dealer tech for Acura and when an Acura/Honda does this its always the IAC valve. I figure it is an engineering problem, and no a Toyota tech won't wave a magic wand and fix it, but complaints do need to be placed so an ECU reflash or sensor signal upgrade can be figured, because at the end of the day it isn't normal. Mine also started pulling left and the suspension is leaning towards the drivers side, all of this will be mentioned at the first oil change.... Good Luck!
Old Jan 21, 2007 | 12:38 AM
Tsuihousha's Avatar
i would complain and take it down there, but unless they know for sure i dont want them messing my car up more. Second i dont want them to see my intake, exhaust, pully etc. and void some stuffs on my warrenty with their sneaky selves =(
