best time to do sway bar end links?
Old Jul 12, 2009 | 01:37 AM
sabiansdrum's Avatar
Default best time to do sway bar end links?
Next weekend I will be doing my suspension, koni's and sportlines all around. But I also have the sway bar end links that I want to put in too.
Here's what i'm wondering, when is it best to do those end links? when I have the front struts out when it's all torn up? OR doing them on their own, either before or after the strut/spring replacement?
Old Jul 12, 2009 | 03:41 AM
burstaneurysm's Avatar
You can really do it whenever, but if you're going to have the wheels off and the strut pulled anyway, why not do it then? It'll only add a few minutes to your work.
Old Jul 12, 2009 | 04:36 PM
Big_Bird's Avatar
I concur.
Old Jul 12, 2009 | 09:37 PM
frbl's Avatar
In fact, I believe someone mentioned that with the end links off (after you remove them, before you put the new ones on), you gain a little bit more room /play for the struts. I wish I had known that when I put my struts on.
I replaced the end links some time after I did the struts, but I wish I would have done them both at the same time. It might have made for a longer work day since I'm new at this kind of auto work, but I think it would have been worth it.
Old Jul 13, 2009 | 01:26 AM
Hey thanks guys, I was thinking that it would be easier but at the same time maybe not. Yes because of what you guys have said, and No because I would think I would have to deal with jacking up the control arm.
If I did them before or after I would probably do it with the car on the ground or on ramps...so no tension on the bar.
but may have to consider the do it all at once idea.
Old Jul 13, 2009 | 06:40 PM
IH8ONYU's Avatar
i just jacked up my box from the side, and used a pry bar to seperate the sway from the controll arm - took all of 5 min per side to do the end links, very easy and i didn't remove the wheels. just need a good jack, jackstands, and a creeper. it might be easier to do while you have the wheels off when you change out springs if you dont have a creeper to slide under the box...
Old Jul 13, 2009 | 11:19 PM
wonderful. I'll just do it all at once and be good to go, hopefully all goes smoothly. It will be this weekend so I don't have to work.
I'm doing it solo so everyone wish me luck!
Old Jul 25, 2009 | 04:54 PM
frbl's Avatar
So? Didja' do it? How'd it go???
Old Jul 26, 2009 | 07:27 PM
dude guys,
I have not done it yet... my landlord called me the 14th to bring a realtor into the house the 15th to price the house to list it. Well, I have 30 days from the 15th so this job has been put on the backburner unfortunately
I'm so ____ed about it, it's like thanks for the crappy notice you wanted to sell the house after 2 years...
But I think once I move I'll do it...but on the other hand I thought about waiting now until spring since winter will blow more 2'' lower... hmmm.......
Monkey343
Scion xD Suspension & Handling
Nov 10, 2016 02:07 PM
JPuehl
Jan 10, 2015 01:01 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
yamahamx117
Dec 25, 2014 01:54 PM
