Let's have some fun! Injector Duty Trivia (all welcome)
Well I was processing MOUNDS of datalog information last night (about 1.5 hours worth) from the new unit we have been working on. Being as though I have this car in my possession for the next 2-4 weeks (so long as I need it), but I was checking out duty cycles after all multipliers and such. What do you think a 550cc injector's max duty cycle would be on a T-tC, with a 54 trim .63 A/R turbine running 5 PSI of boost at 100% throttle with an AFR 11.5:1?
Cliff notes
54 trim; .63 A/R turbine @ 5 PSI
Temp was 65 degrees
750 ft above sea level
11.5:1 AFR at WOT
550cc injector
Stock rail, stock pressure, stock pump
Cliff notes
Temp was 65 degrees
11.5:1 AFR at WOT
550cc injector
Originally Posted by tC_2NeR
6200/60= revs per second.
Each crank rev is: 1000/revs per second=
Availalbe time between firing(x) = x*2=
xx.xx MS/availbe time between firing= IDC%
carbon......check out the video "over 9000" on you tube and then youll get it.....i was hoping someone would get it....but i guess not......why only 6900 paul......and i still want some screen shots of this new engine managment.......stop being all sneaky sneaky
Now that I think about it, it's 'WHAT 9000!'
what car was the carfax for if you dont mind me asking.....oh and sorry for stealing your thread paul
