Bubbalove
07-16-2009, 02:12 PM
I am no wheel expert, and I've been trying to find wheels that I like for a long time now. I think I've finally found some.
The Specs:
17x7
5x100
Will these fit using the stock tires, or does it depend on the wheel offset?
The tc offet is +45mm (I think)...should any aftermarket wheel offset number be lower than this or higher to fit cleanly on the stock tires 215/45/17
Thanks
ack154
07-16-2009, 03:01 PM
The 17x7 is the only part that matters for the tires. And those will be perfect b/c that is the same as the OEM size.
The offset... if you want to get a little more flush, you would get a lower offset. With a 7" wheel you could go as far as probably +30 if you can find it... +35 is a bit more common I think and wouldn't be bad.
XIEmperorIX
07-16-2009, 04:13 PM
^x2 with what ack said...those specs (wheel size and offset) are pretty much the same as the stock wheels..I think our stockers are 47mm?
Anyway - try and find a lower offset..IMO it looks better when the wheels aren't pushed so far in..or you could always slap a good 10mm spacer on there if that's what you have your heart set on
XIEmperorIX
07-16-2009, 04:19 PM
oh ok so those wheels are the exact same as our stockies
Bubbalove
07-16-2009, 05:44 PM
Ok so the offset for the wheels that I'm trying to get is +38mm, will the will fit on the stock tires?
Bubbalove
07-16-2009, 05:54 PM
I also found a wheel that is a 17x7.5 will that fit on the stock tire?
ack154
07-16-2009, 06:32 PM
Both of the above are OK. The offset will not affect the tire size at all. It just affects how the wheel fits on the car and a +38 would be perfectly fine (and look a little better than the OEM +45).
A 7.5" wheel should also fit the 215 tire (OEM tire width) but you may want to consider a 225 at some point.
