Official E85 thread
Im planning on setting up my aem box to run both E85 and pump gas on the fly by using the nitrous control feature.
Question is does anyone currently run it?
How do you like it?
What power have you made?
What mpg do you see?
How do you like it?
I would run it but worried about what hardware components in the fuel system may fail since alcohol is some bad stuff. Right now, I've got a walbro and return setup with aeromotive FPR. I have no clue if the rest of the system will tolerate e85. Anyone have thoughts on this?
from my understanding modern fuel systems do a much better job holding up to alcohol. I think our only weak points lie in the pump and too small injectors, but once those are replaced you are good to go. That walbro pump will work just fine too. I plan on running it whenever my car decides not to hate me
Most modern fuel systems are designed with ethanol in mind. However sometimes when they are not designed to run with a high percentage of alcohol you can run into problems of deterioration of rubber components such as the fuel filler neck which can end up in the tank and consequently in the pump screens or worse yet in the injectors pintles.... It's happened before.
However I have never tried it with a Scion but who knows. Might be a good idea, would make good power. Definately need larger injectors, maybe two rails.
So here's the replace list so far:
injectors
fuel rail (preferably return fuel setup)
fuel pump
possible fuel filler neck (anyone make these aftermarket???)
OR Fuel cell in-car and remove the stock tank
anything else to add?
injectors
fuel pump
you might read this thread and ask rasta what he has done to his fuel set-up he is running 350hp tuned on hydra with 1000ccs on E85
https://www.scionlife.com/forums/vie...t=e85&&start=0
Just as long as you realize you cant just easily switch back and forth. You gas milage will go down between 15-25% depending on tune. On methanol you are suppose to run a good bit more fuel, I don't remember the exact percentage but it all depends on your setup and final tune. I am sure it will require 15-20% more fuel due to the AFR is required when running E85.
Also, if you're running 1000cc injectors, when you switch back to pump and are using less fuel, would those larger injectors cost you MPG?
