Need help quick. exhaust turbine loose
Old Jul 22, 2009 | 06:52 PM
athletefeet66's Avatar
Default Need help quick. exhaust turbine loose
my exhaust turbine blades are scraping against the backplate of the exhaust housing, which is loose and spins.
is there any way to get the backplate to stop moving?
its a big 16g btw
pics coming soon because i dont know if my terms are accurate
Old Jul 22, 2009 | 07:05 PM
Old Jul 22, 2009 | 08:19 PM
DezodDon's Avatar
It is normal for that shim plate to spin. If it didn't you would have problems. If it didn't it would indicate oil coking up and causing it to not spin. The only thing you need to worry about is shaft play. If you are experiencing shaft play then you need to check for boost leaks.
CombatmedicR56
Nov 12, 2020 01:53 AM
RY_TC07
Jul 18, 2017 05:18 PM
BlackKnight
Sep 15, 2015 06:42 AM
mickkassem
May 12, 2015 03:36 AM
FrostSabre
Apr 28, 2015 11:25 AM
