Dezod Bolt Size for Downpipe to Turbo?
Old Jul 22, 2009 | 06:59 PM
guitarguru44's Avatar
Default Dezod Bolt Size for Downpipe to Turbo?
Hello, does any one know what the specs are for the bolts that connect the downpipe to the turbonetics turbo for the Dezod kit? I need to purchase two of them because apparently they fell off my car when I wasn't looking and I want to know which to buy without having to wait for the car to cool down tonight since the stores will be closed by the time I can figure it out. I obviously need the thread diameter and bolt length.
Thanks, JOE
Old Jul 22, 2009 | 07:33 PM
damn.. I guess I will have to wait for the car to cool down, unbolt a bolt and take it to home depot.. What a pain in the ___ this is since the car is so freakin hot after driving..
Anyone know the size of this bolt?
Old Jul 22, 2009 | 07:46 PM
DezodDon's Avatar
8mmx1.25
Old Jul 22, 2009 | 08:00 PM
Sweet. And now that I am thinking about it I think those might not even be the bolts that I am missing. I think I might need the bolts on the other side between the turbo and exhaust where the flange mounts to. I actually think I might even need a flange but I'll have to look at it again after work.
Are these bolts same size? I assume they would be.
Thanks again, JOE
Old Jul 23, 2009 | 11:56 AM
Yea those were the bolts. Thanks again.
Old Jul 23, 2009 | 12:14 PM
Ace83's Avatar
Ronin Scion
yeah most t3 comes with 8mmx1.25, but never use a home depot bolt they might just break or not withstand the heat.. use a some heat treated or some high grade ones at least a grade 8.. go to autozone or an industrial store or get some nice arp bolts
Old Jul 23, 2009 | 04:37 PM
paul_dezod's Avatar
Scionetics
KAD
Default Re: Dezod Bolt Size for Downpipe to Turbo?
Thanks, JOE
8mx1.25x20
Old Jul 23, 2009 | 05:07 PM
Schuller's Avatar
http://www.boltdepot.com/product.asp...&cm=22&cd=1328
Old Jul 23, 2009 | 06:38 PM
____ that's good to know. I figured the heat would not be an issue for a bolt but I guess it does get extremely hot. I will definitely not install the bolts I just got at home depot and instead go to autozone or a similar store. Maybe home depot even has higher grade bolts, I just grabbed the standard one.
And thanks for the clarification as to 1.25"x8mmx20mm.
JOE
Old Jul 23, 2009 | 06:51 PM
paul_dezod's Avatar
Scionetics
KAD
flip that's good to know. I figured the heat would not be an issue for a bolt but I guess it does get extremely hot. I will definitely not install the bolts I just got at home depot and instead go to autozone or a similar store. Maybe home depot even has higher grade bolts, I just grabbed the standard one.
JOE
Indeed. You can also elect a full hardware overhaul with our hardware kit:
http://www.dezod.com/pd-dezod-motors...rdware-kit.cfm
This includes (old picture on site) black oxide coated Grade 8 DP bolts with lock washers in it.
Old Jul 23, 2009 | 07:48 PM
Joe_Dezod's Avatar
Black oxide coated bolts are the best for sure!
Some Home Depot and Lowes places sell grade 8 bolts in case you run into an emergency and need one really quick. I know they saved my butt a few times before. They have them in a bin area usually to the right of all the standard bolts and hardware.
Old Jul 24, 2009 | 01:31 PM
and how in the hell am I supposed to tighten these bolts. What a pain in the ___. I guess my best bet for getting into those tight spots is a combination wrench? Socket wrench has no room.
Old Jul 24, 2009 | 05:24 PM
paul_dezod's Avatar
Scionetics
KAD
**Wrong post.
rain7905643
Mar 14, 2015 12:48 AM
Genesis
64
Jan 22, 2005 01:02 PM
arinvolvo
Jan 21, 2004 11:40 PM
TrEyHoLyO
Jan 14, 2004 05:13 AM
