TPS wire...
Old Jul 23, 2009 | 06:31 PM
krazyjvilled's Avatar
Default TPS wire...
almost done hooking up my ny-trex triple threat nitrous kit... need to tap into the TPS wire above the pedal... i have read it is the brown wire that i want, just wanted to check with everyone else to see if this is the one they used
Old Jul 23, 2009 | 07:53 PM
anyone?
Old Jul 23, 2009 | 08:07 PM
Joe_Dezod's Avatar
What year is your car?
Old Jul 23, 2009 | 08:09 PM
09 tc
Old Jul 23, 2009 | 08:20 PM
Joe_Dezod's Avatar
I'll email you the pinout guide for the 07+ tC's. It should be the same for 09. Email me at joe@dezodwest.com and I will reply with the attachment.
Old Jul 23, 2009 | 09:01 PM
emailed u... does it show which wire is the tps?
Old Jul 23, 2009 | 11:15 PM
Joe_Dezod's Avatar
Yes. I responded and gave you the pin I would use.
Old Jul 24, 2009 | 03:01 AM
does it show u on the unit itself the pin numbers? ... also, i want to tap into the wire that is above the accelerator pedal, not the one in the engine bay by the throttle body... does this make a difference cuz i think the one u suggested is by the throttle body
Old Jul 24, 2009 | 03:12 PM
no one has anymore information on this? i know alot of people have or are running nitrous
Old Jul 24, 2009 | 04:01 PM
ElevationTC's Avatar
i use the one at ecu..
double
Old Jul 24, 2009 | 06:49 PM
yellowxhoodie's Avatar
yea, i would use the one from the ECU too.
and the pins are not numbered, you just count them yourself.
Old Jul 24, 2009 | 07:28 PM
what do u mean use the one from the ecu? that doesnt make sense... there are the throttle position sensor wires by the throttle body, then the pedal position sensor wires above the pedal... the wires are the same colors for both, and i just want to tap into the pedal ones... im asking if anyone knows for sure if it is the brown wire that controls the voltage of the throttle and pedal sensors..
Old Jul 24, 2009 | 07:35 PM
there is a TPS wire coming out of the ECU.
i used it for my GPS.
Old Jul 24, 2009 | 07:50 PM
are you sure this is the same thing? it is supposed to read when the pedal is at WOT and what not... i really dont think thats the same thing
Old Jul 24, 2009 | 07:52 PM
woops.
my bad, i used my VSS not TPS.
but think about it...
it HAS to go to the ECU.
Joe was nice enough to send you the diagrams so take a look at em and find it.
Sgtfluffy16
Scion tC 1G Wheel & Tire
77
Dec 17, 2023 08:09 PM
dtpmike
Jun 20, 2010 10:26 AM
GreenEnvy06
Scion xB 2nd-Gen Wheel & Tire
Oct 11, 2007 02:32 PM
-lastsciontc-
21
Jul 9, 2007 11:19 PM
unseen
24
Aug 12, 2006 04:08 PM
