View Full Version : Rear bumper bolt that rubs
HKSpeed
07-26-2009, 01:10 AM
Today I was looking for a way to deal with that rear bumper bolt that rubs when you're low with aggressive offsets. I saw the flat screw that holds the side skirt and gave it a try. Its about 25% shorter but sits flush against the bumper. Anyone know if using this shorter bolt on the bumper will be a problem? I tugged/pulled the bumper corner and it comes out the same amount with either either the bolt or screw on. I guess the original bolt connects the bumper to a plastic bracket and not any metal.
The original bolt (that rubs) is in the center. The side skirt screws are on the sides. I picked them up at the dealer for $1.26 each.
http://i101.photobucket.com/albums/m51/HKSpeed/Picture031.jpg
BlizZard
07-26-2009, 04:23 AM
Why don't you just take that bolt off, Won? I drove without those bolts for months and didn't have any problem
yellowxhoodie
07-26-2009, 07:56 AM
no bolts FTW!
i know its the front and not the rear...
but my front bumper is only held on by 2 clips underneath the hood. :P
Air2TheThrown
07-26-2009, 06:00 PM
You can remove the rear bumper bolts no problem. Pretty much everyone that runs aggressive setups have shaved the rear bumper so the bolt can't be put back.
Aroddalobster
07-26-2009, 09:09 PM
or you can sand/shave down the bolt itself, like sky-on did. sits a lot more flush, and the ratchet head still catches on to it and cover it over with electric tape.
i personally haven't had a bumper bolt on for over a year now, and i drive 70 miles daily.
sky-on
07-28-2009, 07:55 AM
only reason I'm still running the bolt is because my bumper is cracked at the mounting point, otherwise i wouldn't be running the bolt either, Won you should be fine w/o it, the rear bumper is super reinforced, you can all thank Toyota for over-engineering EVERYTHING on our cars. lol
