Why i wont be using je pistons ever again!
Old Jul 27, 2009 | 03:49 PM
ElevationTC's Avatar
Default Why i wont be using je pistons ever again!
Is because now my car sounds like a disel truck!
piston to wall cleanrce was .0030
and ive been reading this is a issue with using the je's!
Whats the reason for this.. and will i have a issue later on?
Old Jul 27, 2009 | 03:51 PM
BlackKnight's Avatar
Music City Scions
Who did the machine work on the engine and who assembled it?
Old Jul 27, 2009 | 03:56 PM
Cft uses titan motorsports for all there motor work.
So titan motorsports did all work..
And they told me about this before they even assembled the motor
Old Jul 27, 2009 | 04:05 PM
j0hnBlaze's Avatar
*watching
Old Jul 27, 2009 | 04:18 PM
SoFloTC's Avatar
brett561 also has JE's and he said it sounded like that to but hes been running on them for a while
Old Jul 28, 2009 | 04:04 AM
aen's Avatar
aen
diesels sound mean.
Old Jul 28, 2009 | 04:07 AM
rangerryda's Avatar
Hmm, turbo diesel TC, you should put stacks on your car! Puffing black smoke all the way down the track would be awesome!
Old Jul 28, 2009 | 04:50 AM
Music City Scions
Something just doesn't sound right. JE has been making pistons for a long time if they have issues why are they still in business. I would contact JE and see what they tell you, then I would contact the shop and see what they are going to do.
Old Jul 28, 2009 | 05:06 AM
Soulquarian's Avatar
From what I've read on other car forums, piston slap with JE Pistons is pretty much the norm. Most of them report that as the engine heats up and the metal expands, piston slap should go away though, usually after the first 5 minutes of startup.
Took this from a miata forum:
The key to elimiating piston slap with forged pistons is to runa tapered cylinder wall. Most forged pistons require a large piston to cylider wall gap of aound .004-.005". If that gap is maitained throughout the entire length of the bore the pistons hit the cylinder wall at the bottom of the stroke when the rod is exerting the most side forges on it. If a tapered cylinder wall is used with manufacturers piston spec at the top and about .002 at the bottom there will be no slapping noise. That is what I had done for my forged JE piston equipped FE3.
Old Jul 28, 2009 | 05:36 AM
Guru's Avatar
Pretty normal. The fit and finish on JE pistons is god aweful. They are always loud. I use Wiseco and running 0.035 clearance they are quiet as stock.
Old Jul 28, 2009 | 07:42 AM
rhythmnsmoke's Avatar
Music City Scions
I need a visual confirmation please..
Old Jul 28, 2009 | 07:45 AM
SoFloTC's Avatar
ya i got CP and there quiet as hellllll
Old Jul 28, 2009 | 09:35 AM
Domo's Avatar
x2, make a vid
Old Jul 28, 2009 | 11:11 AM
Music City Scions
I am glad you said that because those are what I have. I still find it hard to believe this is a common issue with JE and people still use them. Something just doesn't add up. How did the shop bore your cylinders did they align bore and use a machine or by hand?
Old Jul 28, 2009 | 11:37 AM
Have you never herd of titan motorsports?
they are not some back yard mechanic!
And yes, once motor is up to full temp the noise goes away.. i should note this is only during warm up...
Just installed my oil pressure gauge. 35-40 at idle. then increases about 10 psi per rpm thats at normal driving temps..
Couple very hard highway pulls idle oil pressue is 29 psi..
And i went by the shop yesterday and the guys took a listen and drove it and said everything was PERFECT! And asked me when im turning it to 27 pounds!
Old Jul 28, 2009 | 11:50 AM
Music City Scions
I've heard of them but don't know anything about them. I wonder if you had the piston head ceramic coated and the skirts coated if it would help any.
Old Jul 28, 2009 | 12:12 PM
yamaha16bw's Avatar
Ive heard this before about JE's. I used Wiseco and they are quite.
Old Jul 28, 2009 | 12:30 PM
vettereddie's Avatar
I'll be running Wiseco's, but for the 1NZ-FE, they (Wiseco) recommended .003" clearance like the JE. I did get them coated before sending them to the engine shop, so clearance is w/ the coating on. Sides did get the dry lube coating, still doing re-assembly so not sure how it's going to sound yet.
Old Jul 28, 2009 | 02:00 PM
TCpete's Avatar
its common mike for that to happen.. how come u didnt switch over since titan told you about it? is the sound that bad?
Old Jul 28, 2009 | 02:37 PM
rangerryda's Avatar
Piston slap is common on GM trucks and the older Camaro's and Trans-Ams. Once they heat up, it all goes away. Just put some glow plugs in
