Putting wire through firewall
Old Jul 30, 2009 | 10:31 PM
skinnayyy's Avatar
Team Scionara
Default Putting wire through firewall
Where would be the biggest hole that i could use to put a wire through my firewall? I'm installing my underglow and if possible i would want to put it through the fire wall, but as of right now i can't find anything big enough, the plug is about an inch wide, but only a quarter inch if that thick.
Old Jul 30, 2009 | 10:34 PM
yeldak's Avatar
there is a large rubber grommet that your main harness goes through. you can use that. lay on your back on the floor under the driver side dash with a flashlight and you'll see it up there.
Old Jul 30, 2009 | 10:37 PM
BZinn1's Avatar
there are wire grommet paths on both sides of the fire wall,just untape the ends and get a coat hanger and push it through to a person on the other side,then tape wire on to it and feed it through,once in place retape the grommet and good to go.
Old Jul 31, 2009 | 12:51 AM
BlueFin's Avatar
I used the one behind the glovebox. you can unscrew the ecu box and you can access it very very easy. A lot easier than the driver's side one. I used a small knife to poke a small hole and pushed it throw. If I can do it, you can do it for sure...cause i had know idea how to do it at first until i decided just to go for it. plus mine is a 4 guage wire
Old Jul 31, 2009 | 03:39 AM
skinnayyy's Avatar
Team Scionara
i'll be able to fit an inch wide wire end through those though? i just want to make sure before i start doing all that and then not be able to
Old Jul 31, 2009 | 03:44 AM
Murphys_Law's Avatar
inch wide? use the grommet unger dash on drivers side, tape it to a coat hanger and push it through
Old Jul 31, 2009 | 04:04 AM
skinnayyy's Avatar
Team Scionara
ok thank! is it easy to get through from the other side in the engine bay?
Old Jul 31, 2009 | 10:45 AM
yeldak's Avatar
yes, it will come out somewhere behind your throttle body if you use the one on the drivers side.
Old Jul 31, 2009 | 12:58 PM
skinnayyy's Avatar
Team Scionara
awesome, now i just have to wait untili tuesday before i can do anything with my car again ><
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
streetracerr
Jul 11, 2015 09:52 PM
skruff
May 6, 2015 08:32 PM
clickclickw00t
Feb 18, 2015 08:57 PM
randode
44
Jun 29, 2004 04:19 PM
