Cathode tube
Old Jan 29, 2005 | 01:57 AM
dctennis10's Avatar
Default Cathode tube
Would tubes like these work in my tC? If so, how would you hook them up?
Thanks for the help. http://www.xoxide.com/bluecathode.html
Old Jan 29, 2005 | 02:23 AM
Max2k's Avatar
Yes, they will work. I'm not familiar with the tC, so I can't tell you how to hook em up.
Old Jan 29, 2005 | 04:02 AM
Jmarks1998's Avatar
http://www.svc.com/ccfltubes.html
This is where I have ordered from twice and have had no problems at all and they are super cheap.
Old Jan 29, 2005 | 04:08 AM
dctennis10's Avatar
yeah but i dont know how to wire them in...
Old Jan 29, 2005 | 04:13 AM
Jmarks1998's Avatar
The transformers I got with mine had red (power) and black (ground) wires coming off of it. Run the ground wire to one side of a switch and the other side of the switch to ground on the chassis of the tC. Then wire the power wire to a power source in the vehicle (cig. lighter, ign. harness, at the radio). If you are wiring them to come on with a door trigger than you wire them up diff.
Old Jan 29, 2005 | 04:21 AM
Dallasintern's Avatar
Hey are their switches that let the power go through and also give you the choice to turn it on or off. Like a dome light switch? That way you can wire it from the dome light to the switch then to the cathode. Is this possible.
Old Jan 29, 2005 | 04:24 AM
dctennis10's Avatar
i bet you could find a switch you could put in one of the empty switch slots...im just not sure where...but thats what id prolly want to do
Old Jan 29, 2005 | 05:14 AM
TheScionicMan's Avatar
Check the Tech section, there's info on all this... Installing lights, switches that fit...
yhwhdesign
Jun 11, 2021 03:34 PM
airmankevin1
Nov 17, 2015 05:44 AM
ScionLife Editor
Sep 15, 2015 04:40 AM
carid
Aug 31, 2015 11:17 AM
