Greddy Turbo Kit with e-manage Ultimate - Won't start.
Old Aug 9, 2009 | 12:42 PM
Prez's Avatar
Default Greddy Turbo Kit with e-manage Ultimate - Won't start.
The car will start on the stock ECU but will not start with the emanage ultimate. Any ideas as to what can cause this?
If we start the car and let it idle on the stock ECU then switch to the ultimate it will start after warm. The car will not start on the ultimate when cold though. What settings do I need to twak for cold start?
Does anyone have a base map to start with I may use? IF so could you please e-mail it to
prez2510 at hotmail dot com . Thanks.
Old Aug 9, 2009 | 12:57 PM
rhythmnsmoke's Avatar
Music City Scions
You try the base map off of GReddy site or Dezod Site?
Old Aug 9, 2009 | 04:30 PM
gingles's Avatar
yo check your email...i sent you a map
Old Aug 9, 2009 | 06:29 PM
beastC's Avatar
make sure ALL of the wires are hooked up properly. MIne was doing the same thing. I contacted greddy and it ended up being my wire for the maf
Old Aug 10, 2009 | 12:45 AM
Prez's Avatar
Thanks gingles and others. Will check into it and try the tune ya sent me. Thank you!
Old Aug 11, 2009 | 07:27 AM
ROCKET77's Avatar
On mine , at first it was a jumper ( it was set at 5v instead of 12v) . After that ,the base map from greddy sucks. It does not work correctly and i downloaded the map from dezod, it fixed most of the issues. I kept it that way for a bit because i could not find a tunning shop around were i live. Now my turbo's leaking oil from everywhere, they tell me its my seals that have gone bad. I sent it to greddy for inspection and rebuilt if necessary.
Old Aug 11, 2009 | 10:44 AM
m6ar2cel6oTC's Avatar
Sounds like a jumpe setting for sure.
Old Aug 11, 2009 | 02:19 PM
paul_dezod's Avatar
Scionetics
KAD
Yep! Check jumper 8 (if I recall)
Old Aug 11, 2009 | 03:34 PM
ValenciaS's Avatar
I agree also on the jumper settings
ILikeTurtles
Scion tC 2G Forced Induction
Mar 6, 2022 02:24 AM
Brammi
Nov 13, 2016 03:46 AM
cessblood
Sep 15, 2015 06:50 AM
my06tc
Jun 25, 2015 12:18 AM
TheTripleC
Jan 4, 2015 06:46 PM
