How to tell if you need to rotors
Old Aug 11, 2009 | 05:16 PM
my06tc's Avatar
Default How to tell if you need to rotors
ok..i have and 06 tc....the other day i noticed the car squeaks when i drive it and squeaks even more when i stop...i check the front brakes there fine the rotors are all rusted dont know if thats normal or not how would i tell if there worned out....im hoping that the rotors is whats causing the noise when the wheels are moving....what do you gies think
i know for a fact that is something with the brakes cause it makes the same noise while im going and more when i stoping maybe the pads needs to be replaced or sanded down...not sure...think i should post some pics i think it would be helpful..this is the drivers side im not on the passenger side so i cant tell
Old Aug 11, 2009 | 06:15 PM
10gxiong's Avatar
i don't think the rotors should be squeaking when you're moving. The only time you'll be hearing any squeaking from the rotors is when you brake (pads and rotors contact).
Old Aug 11, 2009 | 07:43 PM
my06tc's Avatar
something down there is making noise..does make noise when i stop...gonna have it check out...kinda anooying me
Old Aug 11, 2009 | 08:15 PM
rosedaleny806's Avatar
happens to me noisy as hell rolling then when u press on the brake its even noisier, eventually it will get worse. its ur brake pads bro
Old Aug 11, 2009 | 08:17 PM
ack154's Avatar
If the pads are low enough, there is an "indicator" that will start to rub the rotor to tell you it's time to change them.
Check your pads (and the condition of the rotor!).
Old Aug 11, 2009 | 08:22 PM
happyhick025's Avatar
yea i got the same thing in my rear brakes. happens at slower speeds and more so when braking. my guess, like ^, is that the pads are worn and its the sensors. i'm gettin new brakes soon so ill let you know if it stops after
Old Aug 11, 2009 | 08:28 PM
my06tc's Avatar
im goona ge tit check out or take it aprt and inspect everything....something is making contact that shouldnt..rosedaleny806 you pinpointed exactly what im going through....makes noise when your rollin then more when you brake...
Old Aug 11, 2009 | 08:33 PM
yupp happened to me a month and a half ago sounded like metal on metal scraping then when i would press the brake it sounded so much worse like hard metal scraping, i changed my brake pads and voila its gone, its ur front pads definatly man, jus do it soon before it starts effing up ur rotor
Old Aug 11, 2009 | 08:55 PM
my06tc's Avatar
thanks..gonna have it check out tommrow..i have no time during the week to do it myself and dont wanna wait...as they say if you think something isnt right have it check ASAP...im hoping its the pads.....i havent changed them ever since i bought the car so i guess its time...ill let you know if it solved my problem getting excited here LOL
Old Aug 12, 2009 | 02:43 AM
haha it will definatly be it, get it done!!
Old Aug 12, 2009 | 09:11 PM
my06tc's Avatar
well i had my breaks check out today....turns out to be my rotors as i suspected they are worned...and my pads have plenty of life to them...the rotors have grooves or creases in them big ones which affected the pads with uneven wear and making metal to metal contact..they temporarly fixed it until i get new rotors....which will be done soon...its weird on how they explained it to me...but they said if your getting new rotors i have to get new pads to go along with it...so i think i need a brake job
Old Aug 12, 2009 | 09:27 PM
GammaTNT's Avatar
that is strange the pads are good and the rotors are bad. It is usually the other way around.
Old Aug 12, 2009 | 11:48 PM
my06tc's Avatar
very strange....the pads had grooves in them i guess from the rotor from what i was told could be true could not be...but the pads itself had plenty of life....if you ran you nail flat against the disc you can tell right away theres something wrong...the pads could of done it to the disc some how got worn down to the point where its was scraping the pads making scraping noise...im not a mechanic but from what i saw..
i dont know if its normal or what..but i had a few budddies that had bad rotors and screwed up there pads..i guess from rust or weak metal...
Old Aug 13, 2009 | 12:43 AM
BZinn1's Avatar
if you cahnge your pads,be sure to at least have the rotors turned for a flat new surface or the problem will jsut come right back.
Old Aug 13, 2009 | 03:40 AM
08_Scion_tC's Avatar
Happen to me a couple months back replaced the brakes and rotors, and the noise stopped.
Old Aug 13, 2009 | 05:57 AM
that doesnt seem right? weird
Old Aug 13, 2009 | 11:04 PM
my06tc's Avatar
yup thats what i thought it doesnt seem to be right on what i was told....
im going this weekend to get it fully fixed....goona have it more examined...if i have to get new rotors or pads then i will...but i aggree with you gies it doesnt seem right..but the pads had plenty of life to them..but i saw that the pads had grooves on them the ones inside of the front rotor both sides could of been from the rotors
looked more worned then the pads....i wish i had pictures so you gies can see what i mean but i will see if i can get some
awell getting it fix....thats all...
Old Aug 17, 2009 | 01:16 AM
tdroads's Avatar
U can get rotors turned for $40.00. Yes u need to replace the pads. Heat from the pads cause the rotors to worp which, causes brakes to pulse and grooves to form on the rotors. Once the grooves apear the pads start to wear unevenly. which can cause poor braking. I am on expert on cars but, i do now something about maintaining one myself.
Old Aug 17, 2009 | 01:18 AM
tdroads's Avatar
I forgot good ceramic pads are no more than $50.00 per set. ceramic causes less brake dust
Old Aug 17, 2009 | 06:56 PM
my06tc's Avatar
ok..turns out my rear brake rotor was shot needed to be replace both of them..the fronts werent as bad but i did them also......learn something everyday..i asked about getting the rotors resufaced but they said theres not much life left to them and goona need to be replaced anyway...all fixed and done....
